Bad WIFI with the newest firmware
So I have upgraded the printer to 01.08.02.00 firmware, and ever since I have really bad Wifi signal, allways losing connection, sometimes it fails to send the job to the printer, and almost always I can not watch the camera.
I have a mesh setup with 2x ASUS AX11000 Pro, the main router is in my living room, the Node is genuine 40cm from the printer.
In the router settings, I already did linked my printer with the Node, but still I have the weakest signal ever. I tried 20hz, 40hz, all channels, results the same. I also have a NAS connected via cable to the same router, no issue. Phone has good signal on the Node so its not the router.
Any suggestions?
If you are the adventurous type like me or if you warranty is already done, X1Plus custom firmware is the answer. They use an different wifi driver with much better performance. You also get lots of other features like logging into printer remotely with VNC, G-code console, assisted bed tramming, diagnostic tools and more cool stuff.
