when i print tilted objects i get this bad z seam.
good front side
how the sliced obj looks :
wall gen arachne
speed settings :
im using wol3d PLA, 3 walls 20%infill, 0.4mm nozzle flowrate is calibrated. and PA is on auto.
please help me out
good front side
please help me out
What seam settings are you using? Have you’d tried disabling scarf seam?
i havent touched these settings yet except the position. even at different positions it still occours. i havent tried without scarf. i will give it a go
Turning off scarf should fix your issue. I’ve found it struggles with overhanging surfaces.
i have turned off " smart scarf seam application " is that the only setting i have to change?
Correct
That is looking more like a partial nozzle clog or temperature being too low.
im using 220c. this is quite confusing as the front side is completely fine. i will run some tests tomorrow after performing a cold pull
Does it only do this on this model? If you print something that came on the SD card it will tell you if it is slicer or printer issue.
I seem to have this defect if i am printing an object tilted and at a low layer height ( 0.08 mm)
i messed with the seam settings a bunch and had no improvement. i also tried drying and changing filament brand but it made no difference sadly
i printed this some time ago today. ( 0.2mm layer height )
this print came out fine i think…
