Good morning community
I have a small problem, which is not a problem, I have noticed that when it prints it sometimes makes small jumps, leaving file when it jumps
The retractions are well configured because it does not leave filament trails at any time, not even in the first layers with a lot of detail.
I get the feeling that this is done to fill small gaps that would be without filament, but it leaves little pinpricks when doing so.
Is there any configuration to avoid it?
I have tried normal and spiral retractions but it does the same.
Thank you very much in advance
I have found on the internet that it is solved by changing the top filling pattern.
I haven’t done any testing yet, but seeing the sliced design with the monotonic pattern instead of a continuous line no longer fills those small gaps and I don’t think it will leave those little dots.
You would want to try out the Arachne walls to avoid too much of those jumps. However, even with Classic you would not get those. I would try the Arachne walls first, then move on to other things if this problem is not solved. Also you could submit a support ticket to Bambulab and wait for the response.
thanks for the response
Yes, I have sent a ticket and we have discussed the types of filling.
I’m going to try what you told me.
I’m going to look for that one on the Arachne walls to see if I can find it
