Bambu A1 Mini Timelapse - TURN OFF
I started noticing that after every layer the nozzle was going to the side and back wasting a lot of time on the print. I read up on why it was doing this to find out it’s related to the ‘timelapse’ function. I find this really annoying because of the following:
  1. It seems product designers have prioritised recording a video of a print over actual speed. Like does anyone actually care or watch these videos of their print job?
  2. The setting to turn this functionality off are super confusing. I had the setting on traditional. The manual advises that in traditional mode should not move back to the chute however it does.
Rather than traditional and smooth options. Can we just turn this OFF. I don’t want any videos i want to prioritise the quality of print and the speed. These are the most important factors for me.
I found that changing the PRINT SEQUENCE to “By object” hoping this turns it off. Anyway all in all super confusing and annoying to work this out. I am about to test this now to see if the nozzle wipes after every print or not.
before you click the send button on your slicer, there are 4 checkboxes, uncheck the one that is labled “timelapse”
i have my slicer set to “by object” so I don’t have the option to turn it on, if you have your slicer set to “by layer” (in: global;other;special mode) then you can check or uncheck timelapse
Sending the file in Orca slicer doesn’t have this option.
It does come up on the printer when i go to print however the option was OFF and it was still moving the nozzle wiping on ever layer. But the turning object on worked…
Screenshot 2024-02-08 at 2.21.55 pm
Ok so to make this worse when i try turn the “Printing Sequence” to “By Object” It’s coming up with this purple box around the build plate as shown
Adding multiple parts adds This large purple circle around the part and it won’t allow me to slice the model because of collisions. This does NOT occur when the printing sequence is ‘by layer’. But if it’s by layer i have to endure the wait of the wipe on every layer. PLEASE HELP
You need buffers around the objects because of exactly what it says - collisions. Not collisions of the parts on the plate, but collisions between the print head and already printed parts.
Imagine you were printing this plate BY OBJECT.
First you print all the pink frogs, then it starts printing the blue frog. The print head has to get down to bed level without disturbing the other already printed frogs, it wouldn’t be possible without colliding with the other frogs.
That’s why it forces you to space out the objects so there is space around it for the print head and also a clear path back to the purge wiper. For taller objects you also have to consider the gantry, that’s what the box is you see in your image.
ok so by object means it tries to print one whole object before moving on to the other?
Ok then in this case the collisions and buffer make sense. Then can someone please tell me why when I have the following settings:
Printer Sequence = By Layer
Timelapse = Traditional
When printing:
Timelapse unchecked (off)
Why the head keep wiping on every layer and moving down then back up before it starts the next? Surely this isn’t right?
correct
This doesn’t actually sound like a timelapse issue. Assuming you mean Z goes down and up then no, that’s not the timelapse function doing that, that keeps the same Z value, it just moves X and Y, snaps a photo and continues.
What firmware are you running? There was a new feature introduced in the latest version to detect nozzle clumping.
By probing the nozzle to the edge of the build plate, A1 can automatically detect filament clumping around the nozzle. The detection feature is ON by default runs checking every 8 grams of filament usage, and can be turned OFF in the Print Options menu.
Could this be what you are experiencing? I’ve not updated my firmware so don’t have this feature yet - perhaps someone who has updated can describe exactly what it does and if that is the “problem” you see.
Hi Thanks for the reply.
I updated to the latest firmware ( 01.01.03.00). To be clear I have the mini. I checked and there isn’t a clumping detection in the printer options… Is this only on the normal A1?
Ok I run in LAN mode my printer said it was the latest but realise there is a later firmware. I will update and see how it goes
UPDATE
After updating to firmware 01.02.00.00 and it has fixed the issue.
I have the same issue where it makes a “smooth” time-lapse even though “traditional” is selected!!!
Running latest firmware 01.02.00.00
Just struggling with this on 01.03.00.00 on an A1 Mini.
Traditional timelapse, it’s moving to the waste chute on each layer. Did anyone get to the bottom of this?
I’ve just run two prints, smooth and traditional, with the wipe tower enabled and disabled, and it returns to the wiper in every case.
I’ve had to turn timelapse off permanently for now.
Bambu A1 v01.04.00.00 with AMS here.
Timelapse is screwing Time Estimation because there is no a “Disabled” option, so in the “Preview” you can see the Travels (in blue), there they are always calculated, regardless you decide to check “Timelapse” in the “Print plate” window or not.
However, if you do not check the Timelapse in the Print plate window, the head does not travel as shown in the “Preview”, so that’s an inconsitency and it has to be fixed.
I think the OFF option for the Timelapse is a must. Once OFF, Time Estimation should be more accurate, and checkbox should be also greyed in the “Print plate” window in the same way when “By object” is selected. Easy peasy.
Weird, the blue travel does not appear after the filament change if I check Prime tower option…
Why do software programmers always think they know what’s best for the customer instead of just asking if there should be a “Timelapse Off” option. It’s so simple yet their arrogance stops them from implementing it. Same goes for whoever is in charge of software development.
What’s even dumber is the FAQ says that if the option is enabled, then a timelapse video will be recorded. It’s like saying if the sun rises tomorrow, there will be a video recorded.
The lack of a “Timelapse off” option on my A1 Mini is really annoying. I want fast prints with minimal unnecessary movement, and have no interest in timelapse footage of the prints.
Even in 2.0 the option is not available in the dropdown to disable timelapse altogether - its either “Traditional” or “Smooth” only.
Please fix this Bambu!
Agreed we don’t want this function please let us turn it OFF!
Thanks
