Having problems with stringy / not adhering on inside walls with Bambu’s ASA. I’m using the base settings set on Bambu Lab, does anyone have some recommendations to fix these issues? The box is essentially 12" x 6" x 3". I was printing these cut in half on the P1S with ASA with no issues?
The walls look fine. The overhang though is not great. Not surprised you are seeing overhangs like that with ASA.You’re probably going to want to add supports since ASA tends to print with low fan settings to prevent warping.
You could adjust the filament cooling settings and turn up the fan for overhangs if you want. The issue being that you risk warping.
As already stated, you probably need some supports. Also, I found the default Bambu settings for Bambu ASA way off. The Pressure Advance (K factor) was off.
Looks like a normal ASA underside, actually pretty good considering how looOoooOOoOong that bridge is.
Add supports and you should be fine.
What K factor did you see good results with on your machine?
I am using 0.017 for the K factor. It would be best to run the calibration on your machine to account for any differences.
Will do, was just curious where yours ended up. thanks!
