Bambu Calibrations Should Use Different Sections Of The Build Plate
Flow Dynamics & Flow Rate Should Use Different Sections Of The Build Plate
When running through the calibration process, the printer should print the Flow Dynamics filament up front and the Flow Rate filament towards the bottom of the build plate.
Currently the Flow Dynamics filament has a effect on the auto bed leveling feature due to its print location on the build plate. This requires the plate to be cleaned before proceeding to the next calibration process.
It would be quicker and a quality of life improvement if the printer could print both calibrations without the need to clean the build plate in between.
Yes, i also had the Issues, that string layed on the bed before the print even started.
Making a System where you could place a designated area, where you could do the Calibrations and stuff like that.
Or you rewrite the G-Code and make the head to a different locations,
either way placing fields in the slicer where you change these places is makeable and
user Friendly.
