Bambu Cloud Down?
Cheers,
Here in Germany, Frankfurt Bambu Cloud seems down ? anyone else can confirm ? Mobile App & Desktop App include Cam doesend work. Printer is switching between offline and busy. I tried most turn off and on, log off and in …
Greetings,
been unable to see cam, upload files and some other stuff for a week or so… Status on print sometimes comes in bambu handy… Shitty system
I just started a print in the US - no issues.
ja habe die gleichen Probleme
I agree … sending print jobs to the printer via cloud is an hit-or-miss since quite some time now (EU region). I could send the file to the printer and start it from there manually thought.
Short it worked again, now again offline. Its little bit frustrating…
I stopped getting notifications yesterday, again. They seem to work fine for a few days and then stop working for no reason. Completely unreliable and very frustrating.
Frankfurt, Germany… The same with me too. Started after the last update to 1.2.0.1.
Are you sure your problem is related to cloud unavailability? Have you checked if your BBL printer is still connected to Wifi / WLAN? Try to ping the IP address from the printer from other PC in same local network or alternatively check your connected clients from your Wifi router.
I am asking this because i realize quite often that X1C is disconnecting from Wifi / WLAN. Then all connections to Bambu Studio and Bambu Handy via Cloud are getting broken and remote is not available. I cannot even ping the X1C from local network when the problem suddenly happens every few hours. The only possibility to get X1C connected again to Wifi is to switch the printer off/on.
Does anybody else have similar Wifi / WLAN disconnection problems?
Thanks for your reply my Friend!
I work as a network engineer, so you can trust me if i say its not because my Wifi :smile:
In the past Weeks there much less problems than the time before, so i think its a little bit better.
Greetings,
