Bambu Cool Plate SuperTack Issues PETG - Anyone Else?
Been testing the Cool Plate SuperTack with PETG and I have been having issues with bed adhesion, sometimes it’s ok and other times it is not. It’s driving me crazy and a friend is having the exact same issue.
PLA is sticking super good, like really good to the point I have to really flex to get prints off and the surface finish has been excellent. Impressed with the PLA performance but PETG has just been down right awful. Bambu has been basically plug and play until now, very disappointed with this print bed.
Tested on both my X1C and P1S and tried a range of different bed temps, same issue.
I made sure to do a search before posting and I came across this post but most people are having issues with PLA, I have no issues with PLA. Anyone else having issues with PETG? Thanks.
I have no experience, but, I wish to congratulate you on the best Venom model printed so far.
I am having similar issues with Bambu PETG (basic) as well. PLA is great on this plate but PETG is giving mixed results (no issues with same filament on the Textured PEI plate that came with my P1S).
I had high hopes for this build plate based on the description, and I would prefer to use the same plates on both my P1S’s so I don’t make the mistake of not selecting the correct build plate when printing. I don’t think there is a choice though, the Bambu Cool Plate SuperTack is not reliable for me with PETG at the moment.
I’m on the same boat. I think this plate is by far the best for PLA, but with PETG (using Bambu PETG Basic as well) the first layer just does not stick consistently.
If anyone from BambuLab reads this, I have followed the instructions on the Wiki and changed the printer config to avoid detecting the plate position.
Also, after a couple of prints a bit of coating chipped away while removing the print. No big deal since there are two sides, but that does not give me much confidence on the durability of this plate, since it happened within the first 5 prints…
I also just picked up a Supertack plate for my PETG prints, and am having unsticking issues whenever the model is taller than a few inches.
I’m using PETG basic with the default profile and the profile for the Cool Plate Supertack, and I haven’t been able to finish a print yet :frowning:
I did just get some PETG HF too, so I’ll give that a shot once I finish my roll of PETG
Same issues here with PETG. I’ve tried cleaning/washing the plate before each print, but the adhesion of the first layer is very inconsistent. It seems that the advertising for this plate is misleading since it works very well with PLA but not with PETG.
I do have the exact same issues, seems to me, that the z-offset is set too high for the supertack plate. The flowcalibration is printed in mid-air for the most part and small (circular) parts wont stick at all. Several material-tests (Bambu, Poly, generic) and a few power-cycles later, issue still persists. No issues on the textured PEI plate. There are commands to lower the latter by 0.04mm before orinting, those or similar commands are not present in the Supertack G-code. I think that might be the issue?!
I have the same issue, glue on the plate sometimes helps for larger object. Hope an answer pops up soon. I like the finish on this plate. I works great with PLA.
I have both a P1S and A1.
Bambu Cool Plate SuperTack is absolutle trash for PETG, I have two, want my money back. Nothing helped.
It is absolutely trash for PETG, I have two, want my money back. Nothing helped.
I was looking for this post for confirmation I’m not the only one.
The SuperTack plate should not be advertised as PETG plate, it’s unusable !
The solution for me was purchasing the BIQU CryoGrip Pro Glacier 257x257mm Panda Build Plate for Bambu-Lab P1S/P1P/X1C/X1E/A1. It works great for both PETG and PLA. Anyone want to buy two Bambu Cool plate SuperTacks?
I have the same problem wit PETG first layer is horrible!
Did you get your money back?
I did not even try. I still use one for my A1 since I only print with PLA on that printer.
I got the supertack plate when it first became available, for an X1. Never had a successful first layer. Total waste of time. I just got a P1S, got the supertack plate because it had a discount getting it with the printer. Same problems. In all cases I’ve been using Bambu Basic PLA.
As I write this it looks like I’m going to at least get a succesful print, with a messy first layer - by cranking the bed temp up to 70. But this just makes it false advertising. It isn’t a ‘cool plate’ that saves electricity.
They’ve had what, 6 months or so to figure this out? They must have seen all our complaints. The firmware should have been updated to make it work better / the documentation should have been updated. They should have stopped calling it the cool plate. Or they should have stopped selling it.
I’ve printed quite a bit gray and red PETG on the cool plate with zero issues. Can’t get the green to stick at all. Makes no sense.
