Lately my Bambu Slicer seems to corrupt its (bambustudio.conf) file. Once it is corrupted bambu studio will launch but immediately terminate. If I delete the file it starts up as if it were just installed. This is new as none of my other installations did that. I’m using 01.10.01.50 When you close BBS and reopen you get this message and then it shuts down.
Anyone else seen this?
Have you tried a clean install of Studio yet?
Yes I did, I wouldn’t have asked without doing that.
I’m having this problem too from time to time. Would also like to have a solution. For now a clean install solves it…
i need help because for a while my bambu lab was working great but recently it said the file was corrupted and i need to reinstall it so i did… four times but it still wont work some im wondering what to do and how to do a clean install
You may have done this, but if you are going to re-install, delete all Bambu folders in C:\Users(you)\AppData\Roaming as the uninstall doesn’t remove these (at least mine doesn’t).
Faced the same problem after updating Bamboo studio. ended up uninstalling and reinstalling the program and the problem is solved. Just use Revo for the uninstalling.
