Bambu handy 3.14.0 SD Issues
Using bambu handy 3.14.0 to control my P1S, i can’t go into my SD card and view timelapse or models.
It loads and loads but does nothing, I literally waited 5+ minutes multiple times. If I keep closing the app and then retrying it will eventually display the models and allow me to start a print.
I’ve downgraded the handy app to 3.13.0 and it loads the models and timelapses without issue.
Bambu studio also works fine on PC to load both timelapse and models.
I’ve been having the same issues. I even reformatted and changed the sd card.
Yep, I did both as well. Its the handy app that has the issue.
I can confirm. Same issue here. Downgrading to 3.13.0 fixes the issue.
Thank you for reporting this problem. I have reported the issue to our team and they will provide a fix ASAP.
Latest app update installed 3.15.0
Now it shows a error instead of loading infinite
Printers firmware is newest 01.09.01.00
Error:
Es ist ein Problem aufgetreten. Sie können
den Drucker neu starten oder die Firmware
aktualisieren, um es erneut zu versuchen.
[-20015:0206204751]
Same problem. Yesterday bought first Bambu Lab P1S.Updated FW to 01.09.01.00 and installed iOS Bambu Handy 3.15 and Windows BambuStudio 02.05.00.66. On both apps have a problem with SD access.
On Windows app: File does not exist. [10] <02-12 11:15>
On iOS app: A problem occured. You can restart printer or update firmware to retry. [-20015:0212111549].
It is my first experience. How to fix a problem? Thank you.
My “problem” isn’t a real problem. I have misunderstand how works BambuLab printers because before I have experience with another brands (klipper and marlin). So after uploading my own model and printing it my problem disappeared)
