Missing the actual layer number being printed in Handy. The % done is nice but we really need the actual layer number if there is any manual intervention (captive nuts, etc) required in a print.
Also, now it seems there’s extra steps to monitor temperatures as well.
It would be great if you finally fixed the Bambu mobile app for Android 17 Beta. This issue has been known for weeks now. It is simply unacceptable that there hasn’t been a single statement or any information regarding this.
Android 17 QPR1 Beta 4
Build-Number: CP31.260522.006
Bambu Handy Version: 3.22.0
Bug:
The app starts up to the splash screen and closes after one second.
@SupportAssistant@BambuLab has anything ever been done about this on your end? The app hasn’t been working for me for months!!!
Problem: The “Customize” button in Bambu Handy returns a 404 error when the app language is set to Traditional Chinese (繁體中文). The button works correctly in English and Simplified Chinese (简体中文). Bambu Handy Version: 3.23.0 Platform: iOS Steps to reproduce:
Open Bambu Handy and go to Settings, set the language to Traditional Chinese (繁體中文).
Navigate to a model page that has a Customize option.
Tap the “Customize” button.
Observe that a 404 error page is displayed instead of the customization page.
Change the language back to English or Simplified Chinese and tap the same button — it works correctly.
Problem : Handy App (June 25 2026) feature to add filament to the library by scanning the barcode on the sticker on the Bambu filament box - is NOT working. No data gets filled in on the form.
What I get is the filament dialog opens with no data in it other than the “name” has been pre populated with the date and time of day.
Handy app version; 3.23.0
Platform : iOS 26.5
Steps to reproduce :
open handy app, Devices tab
Scroll to bottom to Filament Library , select Add Filament
Select method - scan to add , scan the barcode portion of the sticker on the flap of the cardboard box the filament is inside of.
Problem: Cannot interact with filament selection dropdown → cannot start any prints Bambu Handy Version: 3.23.0 Platform: Android (17) Steps to reproduce:
Open Bambu Handy
Choose any model, “Prepare to print”, and choose a profile
The “My filament” dropdown is totally non-interactive; no amount of tapping anywhere on it will let me choose a filament.
Pressing the “Print current plate” button will make the “My filament” dropdown flash, indicating that a filament must be selected to continue, but filament selection is still broken.
Screenshot: Other information: Printer is an A1 mini, no AMS
Use a non-beta version and everything will be fine. They’re not going to bother fixing the beta problem. Are you perfectly removing the supports of a failed print?
Whiteout beta testers nothing would work thou, and bambu ignoring that it does not work with beta for months is a relatively bad thing. The version we are running now is 3 months of public release. Would you rater we didn’t report it?
The problem with the Android Beta is still existing. The last release to work is version 3.0.6. There is the possibility to stay on that release. But the report is important as in a couple of months noone is going to be able to use the app if they don’t fix it. It seems that they are still relying on virbox and Android 17 is rigourosly blocking those certificates. So it seems that everyone is going to have that problem if they do not adress it.
I have a pixel device with an official release of Android 17 and I have the same issue. This is unacceptable, it’s a major loss of functionality for a device I just purchased a couple weeks ago.
Problem: Bambu Handy does not shut off light in P1S
Bambu Handy Version (cannot find) Latest as of 17th Sep?
Platform: Android
Steps to reproduce:
Start a print from Bambu Studio.
Using Bambu Handy switch off the light. Choose “Close Anyway” after warning.
Light on/off icon switches to OFF. Light does NOT turn off. Light icon flips back to ON.
Switch light off using printer controls directly. Light icon in app switches to OFF.
Hit a bug the last couple weeks. If I print to my H2C from my iPhone, it always tries to print in .2mm nozzle. After a couple minutes it errors out with “Can’t extrude filament error” and then I have to kill it. If I walk up and hit “print again” it works fine.
