Bambu Lab A1 attempts to feed filament while nozzle still cold
I have my Bambu Lab A1 for some weeks now and noticed the following:
Problem: Before each print Bambu Lab A1 appears to attempt to feed filament while the nozzle is still cold.
When I upload from Studio to the A1 printer then before the print starts, the print head is moved somewhere high up, to the middle of the X-asis. This looks like being part of the homing or Flow Dynamics Calibration procedures.
Then while the nozzle is still cold the printer seems to attempt to feed the filament making a ticking noise (between two and four ticks, number is not consistent).
This sounds like it may wear/damage the extruder/filament cog(s) over time.
Does anyone recognize this?
Is this normal or is this more likely something that needs to be fixed?
Hello Davinciano the clicking is perfectly normal. As you mentioned it happens 2 to 4 times as the print head is homing at the start etc thats ok. its a check that the extruder does.
If it clicks anymore or at another time during the print that is a problem
Thanks. See my response in the linked thread.
