Bambu Lab A1 footprint dimensions
I’m looking to get an A1 soon, but am having trouble finding the dimensions of the footprint that actually touches the surface it sits on, on the wiki. I am aware other parts of the printer will require free space further out to the sides than the base, but I simply want to know how large the surface below has to be for the entire base of the printer to be supported.
The dimensions I am interested in are marked with A, B, and C in the images linked below. If anyone could measure them out, I would be very thankful!
https://immich.naetwaarket.se/s/A1-footprint-dimensions
It didn’t let me upload the images here directly, so I hope posting a link is fine. Got the error: “Sorry, the file you are trying to upload is not authorised (authorised extensions: jpg, jpeg, png, gif, heic, heif, webp, avif, 3mf).” despite them being pngs.
A = 385 ± 4 mm
B = 303 ± 1 mm
C = 410 ± 1 mm (lower case length, not the foot-to-foot length which will be less)
Measured with tape measure, so not massively accurate.
Thank you! For C, it actually was the foot-to-foot length I was interested in, but I understand measuring that is a bit more involved. I’m guessing though that it’s at least 20 mm less than the case itself? If so, it will be fine for my planned placement.
Yes, the feet are a little bit more than 20mm in from the lower case edges (at least on the front where I can see them!).
These are straight from the A1 FAQ.
Top-down measurements 465mm x 410mm
Clearance front and back 195mm and 90mm
Total space needed front to back is 695mm
Yes, those are on the wiki page that I linked. If you look at the images I provided, you’ll see that those are not the dimensions I was interested in. I wanted to know the dimensions of the parts that actually touch the surface below the printer.
Just got my printer! Length C = 372 ± 2 mm
