Bambu Lab A1, how a normal Maintenance end up messing up the bearings
Hello guys
I just want to share my experience , just for anyone else to avoid this.
All started when i tried to maintain the belts as per A1 Maintenance Guidelines | Bambu Lab Wiki , what i did wrong was that i read that you can use WD40 for the guide rail, but I thought that you can also use it for the belts (big mistake, the belts normally working dry).
So when i lubricate the X-Axis, and then start testing the printer i observed that something was wrong, the belt was slipped to the side and start being damaged. So I stop the printer and I remove the purge wiper , I wanted to operate it to be sure that it was the belt that causing the problem, I had read before that it is important to be careful when you remove the purge wiper because you may lose the ball bearings, but i was confident, until i press homing, the the toolhead move to the side, i manage to stop it before loosing most of the bearings.
In the end i end up loosing 3-4 bearings and putting it back as per instruction on the site Repair Guide for Accidental Fall of Steel Bearing Balls on the X-axis Linear Guideway | Bambu Lab Wiki, the only thing that is not clear for my from the instruction in the site is how to put back the left belt block, the instruction says :“Install the 2 screws on the left side of the X-axis belt and the 1 screw behind the toolhead; align the locating pins on the belt block and install the left belt block.” but when you install the 2 screws on the left you actually installing the block.
What i did is i normally install the 2 screw and the block on the left, and tight them, and then I tried to push the triangle screw in the middle of the block and then i tight the screw behind aligning the pins. Can you advise if this is the correct way? and also if the bearing as it seems below are ok, i pushed them from both side before taking the picture?
Also note that i operate the printer afterward and it worked fine, only the belt is on the side of the motor on the right, but I saw that this is a common issue for A1, and maybe it was like this before, i dont know,
Now you know that oil and rubber dont mix (oil attacks and damages rubber via a chemical reaction), you will understand why condoms say dont use vaseline :slight_smile:
