Is there benefits that the h2s 3d printer has over the p2s has if your printing JUST PLA
Meant to say
Other than build size
Probably not anything you would care about if just doing PLA. Dont overlook the A2L either, it may be all you want or need.
You know I haven’t thought about it
its starts off as “just PLA” but then you need PETG because your model melts in the sun or you want to be able to remove supports easily, and then you want TPU to make phone cases, and …
Print volume
H2 had the ability to add cutting heads, laser, etc.
H2 has a better camera setup and sensor package for print error detection.
H2 has the ability to add birds eye camera.
H2 uses 1.5mm belts, P2 uses 2mm belts, 1.5 had been shown to reduce VFAs
H2 has an automatic top vent damper to control chamber temperature - this helps to avoid heat creep issues with PLA
Thank you so much
Primarily for points 4 and 5
It also has a faster motion system and can produce prints about 20% faster. However, if you’re just looking for speed, 2 P2S’s are about the same price…
