Swaptek enables 6-second switches between up to 7 materials. CMYKW color-mixing creates a wide spectrum of colors with 5 spools. FlexFeed extruder prints soft TPU 75A fast, reliable, and easy. AMS 3P provides fully enclosed filament storage and feeding.
This is Bambu Lab P3C, the one many have been waiting for.
Swaptek™: Switch materials, keep things moving.
Build color into a design or combine different materials in one print. Swaptek gives each PrintTool it’s own filament path and heater, avoiding repeated unloading and reloading. Active Pre-Heat gets the next nozzle ready while the current one prints, so printing can resume with the next material within 6 seconds, with the tool-change done in only 3.4 seconds.
Swaptek also accelerates the frequent PrintTool changes needed for broad spectrum CMYKW color mixing. From subtle petal gradients to beautifully shaded figurines, you can create vibrant color transitions with five base colors through layered deposition, without requiring a separate spool for every color.
FlexFeed Extruder: A softer side to 3D printing.
FlexFeed supports both 1.75mm and 2.85mm filaments, while the optional dedicated TPU PrintTool pairs with our 2.85mm TPU for more reliable feeding. Print materials as soft as 75A with up to 3x the maximum volumetric flow rate.
A posable figure used to mean assembling each joint from separate parts. Here the joints come out of the printer already working – 75A TPU printed in place between rigid shells, grippy enough to hold a pose and flexing instead of snapping when it’s handled.
Soft, flexible 75A TPU forms the upper and the sole beneath your foot. Durable 90A TPU forms the outsole where the shoe meets the ground. Two hardness levels, one seamless print. No glue, no assembly.
Mixed Nozzle Sizes: Speed and detail, no more compromises.
The dial, case, and flexible TPU band are printed together as one piece. Fine dial details call for a 0.2 mm nozzle, the case is better suited to 0.4 mm, and the soft band requires a dedicated 0.4 mm TPU nozzle. The P3C combines precision and material versatility in one print. Bambu Studio’s new mixed-diameter toolpath planning algorithm allows each PrintTool to use its own optimized layer height, delivering fine details and efficient printing without compromising either.
Two Open Slots: Build your own system.
The P3C comes equipped with five 0.4mm PrintTools with hardened-steel nozzles and two additional slots for optional tools. With one PrintTool dedicated to each CMYKW color, full-spectrum color mixing is ready right out of the box.
The two open slots give you room for more creative possibilities: 2.85mm TPU PrintTool, finer or larger nozzle sizes, or the CraftTool Kit that adds cutting, drawing, and debossing capabilities. Swaptek automatically switches between CraftTools during compatible projects, letting you focus on creating instead of changing tools by hand.
AMS 3P: Seven spools, right where you need them.
The AMS 3P gives seven filament spools a home inside the P3C, with sealed storage and dedicated internal filament paths that keeps materials organized and ready to print. For moisture-sensitive filaments, the optional dual-slot Dryer Module adds active drying capabilities up to 75°C.
With an integrated design, the P3C frees up valuable space in your workspace by keeping filament storage and feeding neatly inside the body. With 5 built-in bypass feeding ports, even the soft TPU can be routed completely inside the enclosure. No spools hanging off the side, no exposed filament tubes.
Don’t let the number of tools cap your material count. Connect any existing AMS through PrintTool No.1, and the system extends to up to 22 filament spools, unlocking more colors and materials in a single print without changing your workflow.
Designed for everyday ease.
Automatic calibration ensures precise PrintTool alignment, AI monitoring detects issues before they worsen, and on-screen guidance helps you resolve common issues. Spend less time managing your printer and more time bringing your ideas to life.
Precision is essential for tool changers to ensure colors and materials align perfectly. The P3C’s Full Auto Calibration calibrates the Swaptek system and nozzle offsets before printing, ensuring accurate alignment between PrintTools without manual adjustments.
The P3C’s advanced vision system monitors your print from preparation to completion. Before printing begins, it checks the chamber against your slicer settings for potential mismatches. During printing, AI monitoring detects issues such as spaghetti failures, purge-bin jams, and clogs before they become bigger problems.
Finally, the all-new HMS with MiniWiki helps you identify potential causes, explains them in plain language, and provides step-by-step troubleshooting guidance directly on the printer’s screen. Less guesswork, faster troubleshooting, and more time spent creating.
Available now at Bambu Lab Store.
The standard P3C Combo includes the printer, AMS 3P, and five 0.4mm standard PrintTools. Availability and pricing details vary by region. Select features require additional accessories, full details available in Bambu Lab Store.
What full-color print do you hope to test the P3C with? Let us know in the thread below!
