Small but significant correction to everything I’ve written so far in this topic.
I’ve had this printer since around mid-December 2024—so close to two months of use.
Translation: I’m a total noob and have no clue.
TL;DR: The freaking extruder fan was busted. The small 25.5 mm one that’s supposed to cool the nozzle.
Ever since I bought this printer, I noticed a high-pitched sound coming from it.
Since it was a brand-new device, I assumed that was just the normal sound it made. Plus, I keep it in another room, so I could barely hear it.
Imagine a sawmill next to your house—that was the sound.
After dealing with so many clogs and wanting to get to the bottom of it, I removed the extruder with the fan, replaced the thermal paste (which was nothing like a paste—more like dust), and put it back in.
That’s when I discovered the source of the high-pitched noise. I noticed the fan was barely moving.
I dismantled everything again, but this time, I kept all three cables plugged in while holding the fan in my hand.
The poor thing was barely spinning, screaming like a devil, and moving almost no air.
I removed the back seal and tried adding some specialized oil—no change.
The only thing that fixed it? I gently pushed the blades outward until I heard a click. The noise stopped, and the fan started pushing air. Not a ton, but the difference was night and day.
Pushed the blades slightly toward the motor, the noise came back and the fan slowed down a lot.
Conclusion: I received a faulty extruder assembly, which cost me a lot of filament, time, and gray hairs.
A big thank you to the person who assembled my unit.
Also, this model of fan is a joke. If anyone knows a better model, please share.
So, if you were bored enough to read this far—check your extruder fan if you’re dealing with frequent, random filament clogs.
