Create from your world. Start with a scan.
Stay tuned here.
I am hoping this is a laser based system or a hybrid with structured light.
I think if this product can be kept in the around $1000 price bracket, it can be a huge success.
Software is my biggest concern. Scanning is the easy part. Turning the scan into a usable part can a hair pulling nightmare. This would be a good application for an AI powered tool that cleans up the scan and turns it into an STL (gonna take a lot of RAM though).
My hunch is that a lot of people are going to buy this and be disappointed with the results they are getting simply based on them not knowing how to properly post process the scans. There is this thought that a lot of people have that 3d scanning is an instant reverse engineering tool.
Any hint on the scanning rate or the accuracy?
Maybe the printers are nextâŚ
if they mean the âproâ part and it isnât just marketing speak, no way it will be under $1000, if it wants to compete with the other S1 (the one from creality
) , it will be around the $2000 mark
edit/ and just as importantly as the hardware, the software will be the big question mark, i have no doubt that can compete in the hardware, the software takes a long time to make it right
Ah yes, the 3D scanner that doesnât work on black parts (even reflective stickers are useless), but scans the included test model well (white with bright, vivid light colors).
that and the filment crimping device ![]()
I thought to order the Revopoint Pop 4, so i wait but I guess the software will be the problem of Bambulab. And I donât need to much laser as I mostly like to scan humans.
Idk if Pro is just a marketing term. I guess I am not sure what segment they are really aiming at. Like with the R1, they are getting into segments with well established brands. (but honestly they way overbuilt the R1 from what I was expecting them to release).
I am thinking something that can compete with scanners like the Revopoint MetroX.
Reasonably, if they price it around $1000, then have the combo somewhere around $1250 (including things like markers and mounts), that is the perfect balance for something like this.
If they do decide to price it closer to the $2000 mark, I donât think it will be a reasonable purchase for most âprosumersâ when there are so many other great scanners on the market in that range.
This is the huge question mark. I doubt that they are going to be able to make this âuser friendlyâ. If it is true that they are partnering with SCANTECH, they will get a huge head start.
Well, at least Bambu(cini) learned something useful from its previous launch: always include a year next to the launch month. That way people (potential buyers) wonât get confused as to which year or century the respective launch is intended for.
Would a 3mf work better than the regular formatts ? (machine code)
E57 (.e57) â LiDAR & MultiâScan Metadata
- Stores: large point clouds, multiple scan positions, timestamps, calibration data.
- Best for: architectural, industrial, and LiDAR surveys.
- Strengths: open standard (ASTM E2807), preserves full metadata.
only for the price of 1,000 dollars, we all knew it was coming
Many people think that 3d scanners will solve lots of problems. The big problem is the software canât tell the difference between a modeling flaw and an intended deviation. Lets say you scan a 3d printed part. should it take out the layer lines? If it does there are complexityâs in other intended features being removed.
Yes you can combine the scanned model with AI and improve. Who is the target market? if they did the impossible and sold it for 500 They will loose more credibility because of inherit problems. If they sold it for the 2k+ range they will not sell enough. At that price only those that need it will jump in. Many of those already have.
Where it makes sense is for 3d prints, is the scanner only needs to scan to a resolution that is printable.
Yes, you can convert E57 to 3MF format online. Hereâs how:
It is funny that some of their products are named the same.
Yup.
Thatâs a thing that I donât really get with the lates BL releases that are not FDM. They are jumping in product category of something that their average Bambu Lab user canât perform.
And prosumers are very cautious due to a weak software support on their current laser system (thatâs been out for quite a while, btw).
âwho cares if the dullards donât know how to use it, we got their money!â ![]()
I`m just making a point a few of us know a little more about , its why i left the links out , but i appreciate you took the time to search and post , thanks
Thatâs the thing that I forget about a lot. We are FAR from the average users. The average user can not boot up a CAD program and make a cube.
People are going to buy this thing in hopes they can 3d scan some IP protected item and print it out.
People think that a scan is used directly for printing, while this can be the case for some organic shapes that work well for this, its main use with the blue laser is as a high precision measuring tool, so that you can then rebuild (reverse engineer) the part true to dimensions - this by the way is very difficult and the softwares that make it somewhat easier are very expensive
