Bambu Lab Studio missing P1S profiles
Hello everyone,
I have noticed that there are no printer profiles for the P1S in the latest Bambu Studio version. When I select my printer (whether 0.2, 0.4 or other nozzle) I am only offered printer profiles for the X1C. I know that’s not bad in principle, but all other printers show the profiles with the correct name. Is this known? Will there be a solution (bugfix?)? Or is there already a beta where the problem is fixed, if so where exactly is the current beta?
Thank you very much!
Silly question, have you checked to see if the P1S printer is selected in the printer selection area where all the other types of printers are listed? When updating that menu can do weird things and default to only the X series.
Hello,
Yes sure ;-). Please check if you selected P1S you see profile is X1C.
Any ideas?
Thank you!
I have the same issue after upgrading, and yes, I selected the right printer!
i just got p1s and its selected in device and nozzle but only x1c profiles in drop down, thought they had p1s profiles by now. Do people just use x1c profiles for the p1s?
Have you added the PS1 to Printer Selection?
yes its all added properly… from what i found searching forums they say x1c profiles are the same so im printing now with one of those… most recent on the topic i found was december 2023 though
So then you should be able to select the P1S? I guess I misunderstood your question.
The filament settings are the same between the printers because mechanically at the core they are the same.
Hmm i dont get the option…
What you’re seeing is correct.
I have also same issue. I also selected P1S printer here
Welcome to the forum. This thread already has a solution.
