I printed an Easter bunny and it sticks so hard to the print plate that it broke when it was removed, no problem so far, but I can no longer get the rest of the print completely off the plate.
What could be the problem? This extreme adhesion to the plate was already abnormal.
Mine too, I tried isopropyl alcohol (rubbing alcohol) but it look like if I remove a sort of coating, could that be the case ?
I had that problem with Bambu ASA filament.
Same here, I was given a brand new sealed spool of Bambu silk from a friend. Not only does it not print well, there is something in their formula which leaches out then bonds permanently to any plate I have used. This is not only PEI but my engineering plate, Hight Temp plate, PEO and PEA plates. It is the devils spawn second only to TPU.
I now keep that spool around solely as a test subject for trying out new ideas on problem filaments. It’s become the equivalent of a lab specimen at a forensics lab of how not to produce a filament.
I used to just believe that it was silk in general until I tried other silk filaments, nope… it’s Bambu’s recipe that’s at fault. You live and learn is the way I look at it. I would have probably been angry had I paid for it and the person who gave it to me did indeed warned me ahead of time that he stopped buying Bambu’s silk for exactly this reason.
Good info here. I’ve used bambu’s silk on my SMOOTH double sided PEI plate with immaculate results, but today I tried it on my textured pei and I actually cannot remove the calibration strips or a brim that’s only one layer tall - at all. I don’t want to take a metal scraper to it but all of my plastic ones aren’t cutting it. So weird.
I just had the same with silk gold on my smooth PEI plate. I used the gold for lettering in the middle of the print.
Not only did the gold lettering get ripped out of the print, the PEI surface was damaged exactly in the shape of the lettering.
The Bambu lab sparkle PLA used for the rest of the print came away cleanly so it’s definitely something with their silk filament. Like it’s got an acid in it that etches the plate.
eSun PLA silk did not do this - I’ve used plenty of that with no problems.
Have never used glue before for PLA but will have to now, to get through this roll.
Really disappointing given it’s twice the price.
Here is pretty much undeniable proof that it is the silk filament destroying the plate.
I have a multi coloured model here that is mostly bambu lab PLA sparkle. It has the Bambu Lab Silk PLA gold lettering. The PLA sparkle part of the print pulled away from the plate with absolutely no issue. The lettering etched itself into the plate and is permanently embossed into the plate now.
This is the same brand, same temperatures, same everything. Printed with the AMS. Pretty clear it’s the Silk PLA
Pretty sure I destroyed one side of my build plate like this also. It should be “required” to use glue instead of “recommended” and warn about destroying your build plate surface.
I am really glad I found this thread. I will use glue with the rest of my Bambu Silk filament and probably won’t purchase any more of it…
Use a Dab of Acetone to get that off the textured plate. it should work better than IPA. you poor saps with the ruined PEI sheets though. good to know that I shouldn’t use silk on that sheet.
I have never understood how BL filaments require glue when I have never used glue on any print with any PLA, PETG or TPU.
I have used every sub-type of PLA including silks, I have never had a problem getting it to stick or release and certainly no marks afterwards on the build plates.
This was as true before I moved to BL printers as it has been with several BL printers.
All I hear about BL filaments is they ruin the AMS, jam the AMS, weld themselves to or ruin build plates.
I can only imagine what they are putting in them.
I have some BL PLA basic which work fine and some BL PLA Matte I have yet to try, fingers crossed.
My Flashforge guider 2 used these and I would have to use glue for TPU, and Silk would degrade them so fast that after about a month of heavy silk use I would have to recondition it with acetone to make it stick to silk again but I could only do that 1 or 2 times before it would start to crack the surface. Let me tell you getting these off with a heat gun to replace them and using goo gone on the adhesive left behind on the spring steel was probably the single most frustrating thing ive ever done in relation to 3d printing. Build Tape×5(pcs) For Flashforge Guider 2/2S 3D Printer
I have managed to recreate this problem using Bambu Silk PLA purple, for some reason the dual red blue kind didn’t cause this problem, as you can see a thorough scrub with acetone has removed it from the textured plate. I hope this helps
I had the same issue using TPU. The surface of the PEI plate was severely damaged. I found a neat solution. Using 3M Blue Painter’s Tape I covered the plate surface (omitting the ID piece) and it worked fine. I only had to pull the blue tape off the plate for a perfect result. There is only a very slight texture from the blue tape but it is very minor.
I am using glue now with Bambu silk with no issues.
I found the screenshot you shared after the issue occurred. Unfortunately I was using the Bambu specs for the smooth PEI sheet which doesn’t mention different types of PLA just says PLA requires glue.
I submitted a support request asking for this information to be added to the smooth PEI sheet data table so others don’t suffer the same fate.
It isn’t the end of the world once glue is used, just have to remember to apply if using silk
what brand filament and what printer do you have, i will give the settings i use if i got it😇
i make cansleave from tpu for six years now👍 great result. 0% stringing,100% transparent. sold so so many, prolly hundreds in each color that esun has.
You have probably found answers to this issue and may I add a possibility. The bed temp may be too high. An answer to cleaning the bed is Klean Strip Brush Cleaner by Barr. Use protective gloves. Take the plate outside when you clean it. Set the plate on something level, put a paper towel on the plate, pour enough on the plate to cover the plate and let set 10-15 minutes. If the towel dries out a bit, add more Brush Cleaner. When the time is up, use the wet towel to rub the area of concern and the melted plastic should come off the plate. It may take a couple tries. When it dries, wipe it down with alcohol and it should be good to go. Mine came out looking and working like new.
