Bambu Studio 01.07.03.50 Mac Oops!
A picture is worth a thousand words. Try again!
hello
can you open the previous version?
and did you set your security to let the app run from app store and identified developers?
You just need to open the app from the folder.
That is from the Applications folder.
I have downloaded, opened, and used every version since 1.06.02.04 including a beta version. When I got the X1C in May I went through this with the initial version. This is the First one since that has failed on this parameter.
Retried the download and install, keeping the older versions until satisfied the new one works. BS 01.07.03.50 is BS 3 and it worked. Thanks. Now if it would allow me to use the LAN to use the
camera that would be great.
Sorry for the undetailed answer.
Usually, the Studio app does not require a workaround, but some parts may be missing the proper signature.
My suggestion is to follow the same procedure for installing Orca, the fork o BL Studio:
Source: GitHub - SoftFever/OrcaSlicer: G-code generator for 3D printers (Bambu, Prusa, Voron, VzBot, RatRig, Creality, etc.)
Let me know if you still have issues, as there are other alternatives.
