New version of Bambu studio 2.0.0.95 does not recognize any more my P1P updated (with enclosure kit ), as P1S , does anyone else have this problem?
(Older version working fine and recognize the p1p as P1S .)
Yes, same issue with my printer.
I also have a P1P that was upgraded to a P1S.
The message that the wrong printer is selected appears when I synchronize the filament. The P1P is required before the filament is synchronized. With the P1S setting, the filament cannot be synchronized. I have to first switch the printer from P1S to P1P.
The print dialog, however, correctly assumes the P1S. If the P1P is selected, the dialog indicates that the wrong printer is selected.
I’m working around this for now:
- Switch to P1P
- Synchronize the filament
- Switch back to P1S
I’m also having issues. Tried to do a multicolor print, after slicing it only showed one color
Ok, I agree with that, but I don’t see the settings from the filaments I have saved.Bambu said they will fix it soon this issue ,I have currently downgraded the studio and am awaiting the fix from them.
Didn’t notice, I’ve just used the P1S profile and got rid of the P1P updated profile.
They are aware and working on it.
Yes, I have the same issue. Really annoying!!
Encountering the same issue is very annoying to use. The synchronization of consumables keeps giving warnings, and there are warnings when sending as well, making it troublesome to switch back and forth.
Ok , with the new release, problem solved ![]()
Why have they taken the printing time details off on the Multi-Device screen in BS? this was my go to screen to keep an eye on my printers.
It would also be useful if BL returns the different fan speed indicators to the Device Status main page again. I have issues with my enclosure getting to hot and I need to monitor this to prevent heat creep on some of my prints.
It would also be useful if if we can monitor a maximum of 6 printers on BS to have at least 6 video displays made available on the Multi-Device screen.
My P1P I upgraded to a P1S the software no longer allows me to use the P1S as my machine in BS.
The P1P P1S issue has been fixed with the latest update. That was quick thanks BL
