Bambu Studio 2.9.2.62 is broken. DO NOT UPDATE
Due to newly introduced filament grouping bugs, printing of some models from Makerworld is broken. Do not recommend updating.
Would you like to share some additional details perhaps?
I printed a file from MakerWorld. Then, updated to the new version of Bambu Studio and tried to print the same model again and got the following error after synchronizing my filaments.
It happens on many (but not all) models downloaded from MakerWorld.
I’m using a P2S with AMS 2 Pro. Let me know if you want any more info.
I’m also just realizing that I don’t have to synchronize AMS on every print and that could be causing this. But still, it’s something that worked before the update and doesn’t now. So, I guess the new version is broken (for the way I’ve always used it). :grimacing:
I just updated and I am getting the same issue :confused:
I can confirm a similar issue on my P2S after updating to Bambu Studio 2.9.2.62.
Error: grouping result does not cover filament 4 (old=3 new=5 used=1)
I found a workaround that allowed me to slice successfully:
  1. Synchronize the AMS filaments using Overwrite.
  2. Attempt to slice the plate (the grouping error occurs).
  3. Synchronize the AMS filaments again, but this time select Map instead of Overwrite.
  4. Slice the plate again.
This resolved the error in my case. It appears that the Overwrite operation may leave the filament grouping in an inconsistent state that the subsequent Map operation corrects.
You are the boss!!! Worked like a charm.
