mattt
January 3, 2026, 10:02am
1
Can anyone else reproduce this crash? I’m on 2.4.0.70 on M1 Mac on macOS Sequoia.
Create new project
Open bed context menu > Add Primitive and put a curved object (e.g,. cylinder)
Click on it > Add Part > SVG
Bring a SVG in
Check the ‘Surface’ option
Then resize the SVG.
The dimensions slider might work, but if you manually edit the dimensions of the SVG, BS will crash out. Also crashes out with some of the other options.
I thought it was specifically the model I was working with or specifically the SVG but it’s not as using very vanilla objects and a very simple SVG does it.
This appears to be the relevant bit of the dump:
Relevant Dump
Thread 24 Crashed:
0 BambuStudio 0x105e7fda4 __gmpn_mul_1 + 140
1 BambuStudio 0x105e84cd8 __gmpn_mul_basecase + 44
2 BambuStudio 0x105e7de84 __gmpz_mul + 344
3 BambuStudio 0x105e7f660 __gmpq_mul + 640
4 BambuStudio 0x105d128fc __gmp_expr<__mpq_struct [1], __gmp_binary_expr<__gmp_expr<__mpq_struct [1], __gmp_binary_expr<__gmp_expr<__mpq_struct [1], __mpq_struct [1]>, __gmp_expr<__mpq_struct [1], __mpq_struct [1]>, __gmp_binary_multiplies>>, __gmp_expr<__mpq_struct [1], __gmp_binary_expr<__gmp_expr<__mpq_struct [1], __mpq_struct [1]>, __gmp_expr<__mpq_struct [1], __mpq_struct [1]>, __gmp_binary_multiplies>>, __gmp_binary_minus>>::eval(__mpq_struct*) const + 52
5 BambuStudio 0x105d127b0 __gmp_expr<__mpq_struct [1], __mpq_struct [1]> CGAL::determinant<__gmp_expr<__mpq_struct [1], __mpq_struct [1]>>(__gmp_expr<__mpq_struct [1], __mpq_struct [1]> const&, __gmp_expr<__mpq_struct [1], __mpq_struct [1]> const&, __gmp_expr<__mpq_struct [1], __mpq_struct [1]> const&, __gmp_expr<__mpq_struct [1], __mpq_struct [1]> const&, __gmp_expr<__mpq_struct [1], __mpq_struct [1]> const&, __gmp_expr<__mpq_struct [1], __mpq_struct [1]> const&, __gmp_expr<__mpq_struct [1], __mpq_struct [1]> const&, __gmp_expr<__mpq_struct [1], __mpq_struct [1]> const&, __gmp_expr<__mpq_struct [1], __mpq_struct [1]> const&) + 108
6 BambuStudio 0x105d32d94 CGAL::TriangulationProjectionTraitsCartesianFunctors::Projected_orientation_with_normal_3<CGAL::Projection_traits_base_3<CGAL::Simple_cartesian<__gmp_expr<__mpq_struct [1], __mpq_struct [1]>>>>::operator()(CGAL::Point_3<CGAL::Simple_cartesian<__gmp_expr<__mpq_struct [1], __mpq_struct [1]>>> const&, CGAL::Point_3<CGAL::Simple_cartesian<__gmp_expr<__mpq_struct [1], __mpq_struct [1]>>> const&, CGAL::Point_3<CGAL::Simple_cartesian<__gmp_expr<__mpq_struct [1], __mpq_struct [1]>>> const&) const + 124
7 BambuStudio 0x105d32bb0 CGAL::Sign CGAL::Filtered_predicate_with_state<CGAL::TriangulationProjectionTraitsCartesianFunctors::Projected_orientation_with_normal_3<CGAL::Projection_traits_base_3<CGAL::Simple_cartesian<__gmp_expr<__mpq_struct [1], __mpq_struct [1]>>>>, CGAL::TriangulationProjectionTraitsCartesianFunctors::Projected_orientation_with_normal_3<CGAL::Projection_traits_base_3<CGAL::Simple_cartesian<CGAL::Interval_nt>>>, CGAL::Exact_converter<CGAL::Epeck, CGAL::Simple_cartesian<__gmp_expr<__mpq_struct [1], __mpq_struct [1]>>>, CGAL::Approx_converter<CGAL::Epeck, CGAL::Simple_cartesian<CGAL::Interval_nt>>, CGAL::Vector_3CGAL::Epeck , true>::operator()<CGAL::Point_3CGAL::Epeck , CGAL::Point_3CGAL::Epeck , CGAL::Point_3CGAL::Epeck >(CGAL::Point_3CGAL::Epeck const&, CGAL::Point_3CGAL::Epeck const&, CGAL::Point_3CGAL::Epeck const&) const + 492
8 BambuStudio 0x105d32618 CGAL::Triangulation_2<CGAL::Projection_traits_3<CGAL::Epeck, true>, CGAL::Triangulation_data_structure_2<CGAL::Triangulation_vertex_base_with_info_2<unsigned long, CGAL::Projection_traits_3<CGAL::Epeck, true>, CGAL::Triangulation_vertex_base_2<CGAL::Projection_traits_3<CGAL::Epeck, true>, CGAL::Triangulation_ds_vertex_base_2>>, CGAL::Constrained_triangulation_face_base_2<CGAL::Projection_traits_3<CGAL::Epeck, true>, CGAL::Triangulation_face_base_2<CGAL::Projection_traits_3<CGAL::Epeck, true>, CGAL::Triangulation_ds_face_base_2>>>>::orientation(CGAL::Point_3CGAL::Epeck const&, CGAL::Point_3CGAL::Epeck const&, CGAL::Point_3CGAL::Epeck const&) const + 100
9 BambuStudio 0x105d39f38 CGAL::Triangulation_2<CGAL::Projection_traits_3<CGAL::Epeck, true>, CGAL::Triangulation_data_structure_2<CGAL::Triangulation_vertex_base_with_info_2<unsigned long, CGAL::Projection_traits_3<CGAL::Epeck, true>, CGAL::Triangulation_vertex_base_2<CGAL::Projection_traits_3<CGAL::Epeck, true>, CGAL::Triangulation_ds_vertex_base_2>>, CGAL::Constrained_triangulation_face_base_2<CGAL::Projection_traits_3<CGAL::Epeck, true>, CGAL::Triangulation_face_base_2<CGAL::Projection_traits_3<CGAL::Epeck, true>, CGAL::Triangulation_ds_face_base_2>>>>::includes_edge(CGAL::internal::CC_iterator<CGAL::Compact_container<CGAL::Triangulation_vertex_base_with_info_2<unsigned long, CGAL::Projection_traits_3<CGAL::Epeck, true>, CGAL::Triangulation_vertex_base_2<CGAL::Projection_traits_3<CGAL::Epeck, true>, CGAL::Triangulation_ds_vertex_base_2<CGAL::Triangulation_data_structure_2<CGAL::Triangulation_vertex_base_with_info_2<unsigned long, CGAL::Projection_traits_3<CGAL::Epeck, true>, CGAL::Triangulation_vertex_base_2<CGAL::Projection_traits_3<CGAL::Epeck, true>, CGAL::Triangulation_ds_vertex_base_2>>, CGAL::Constrained_triangulation_face_base_2<CGAL::Projection_traits_3<CGAL::Epeck, true>, CGAL::Triangulation_face_base_2<CGAL::Projection_traits_3<CGAL::Epeck, true>, CGAL::Triangulation_ds_face_base_2>>>>>>, CGAL::Default, CGAL::Default, CGAL::Default>, false>, CGAL::internal::CC_iterator<CGAL::Compact_container<CGAL::Triangulation_vertex_base_with_info_2<unsigned long, CGAL::Projection_traits_3<CGAL::Epeck, true>, CGAL::Triangulation_vertex_base_2<CGAL::Projection_traits_3<CGAL::Epeck, true>, CGAL::Triangulation_ds_vertex_base_2<CGAL::Triangulation_data_structure_2<CGAL::Triangulation_vertex_base_with_info_2<unsigned long, CGAL::Projection_traits_3<CGAL::Epeck, true>, CGAL::Triangulation_vertex_base_2<CGAL::Projection_traits_3<CGAL::Epeck, true>, CGAL::Triangulation_ds_vertex_base_2>>, CGAL::Constrained_triangulation_face_base_2<CGAL::Projection_traits_3<CGAL::Epeck, true>, CGAL::Triangulation_face_base_2<CGAL::Projection_traits_3<CGAL::Epeck, true>, CGAL::Triangulation_ds_face_base_2>>>>>>, CGAL::Default, CGAL::Default, CGAL::Default>, false>, CGAL::internal::CC_iterator<CGAL::Compact_container<CGAL::Triangulation_vertex_base_with_info_2<unsigned long, CGAL::Projection_traits_3<CGAL::Epeck, true>, CGAL::Triangulation_vertex_base_2<CGAL::Projection_traits_3<CGAL::Epeck, true>, CGAL::Triangulation_ds_vertex_base_2<CGAL::Triangulation_data_structure_2<CGAL::Triangulation_vertex_base_with_info_2<unsigned long, CGAL::Projection_traits_3<CGAL::Epeck, true>, CGAL::Triangulation_vertex_base_2<CGAL::Projection_traits_3<CGAL::Epeck, true>, CGAL::Triangulation_ds_vertex_base_2>>, CGAL::Constrained_triangulation_face_base_2<CGAL::Projection_traits_3<CGAL::Epeck, true>, CGAL::Triangulation_face_base_2<CGAL::Projection_traits_3<CGAL::Epeck, true>, CGAL::Triangulation_ds_face_base_2>>>>>>, CGAL::Default, CGAL::Default, CGAL::Default>, false>&, CGAL::internal::CC_iterator<CGAL::Compact_container<CGAL::Constrained_triangulation_face_base_2<CGAL::Projection_traits_3<CGAL::Epeck, true>, CGAL::Triangulation_face_base_2<CGAL::Projection_traits_3<CGAL::Epeck, true>, CGAL::Triangulation_ds_face_base_2<CGAL::Triangulation_data_structure_2<CGAL::Triangulation_vertex_base_with_info_2<unsigned long, CGAL::Projection_traits_3<CGAL::Epeck, true>, CGAL::Triangulation_vertex_base_2<CGAL::Projection_traits_3<CGAL::Epeck, true>, CGAL::Triangulation_ds_vertex_base_2>>, CGAL::Constrained_triangulation_face_base_2<CGAL::Projection_traits_3<CGAL::Epeck, true>, CGAL::Triangulation_face_base_2<CGAL::Projection_traits_3<CGAL::Epeck, true>, CGAL::Triangulation_ds_face_base_2>>>>>>, CGAL::Default, CGAL::Default, CGAL::Default>, false>&, int&) const + 320
10 BambuStudio 0x105d39868 CGAL::Constrained_triangulation_2<CGAL::Projection_traits_3<CGAL::Epeck, true>, CGAL::Triangulation_data_structure_2<CGAL::Triangulation_vertex_base_with_info_2<unsigned long, CGAL::Projection_traits_3<CGAL::Epeck, true>, CGAL::Triangulation_vertex_base_2<CGAL::Projection_traits_3<CGAL::Epeck, true>, CGAL::Triangulation_ds_vertex_base_2>>, CGAL::Constrained_triangulation_face_base_2<CGAL::Projection_traits_3<CGAL::Epeck, true>, CGAL::Triangulation_face_base_2<CGAL::Projection_traits_3<CGAL::Epeck, true>, CGAL::Triangulation_ds_face_base_2>>>, CGAL::Default>::insert_constraint(CGAL::internal::CC_iterator<CGAL::Compact_container<CGAL::Triangulation_vertex_base_with_info_2<unsigned long, CGAL::Projection_traits_3<CGAL::Epeck, true>, CGAL::Triangulation_vertex_base_2<CGAL::Projection_traits_3<CGAL::Epeck, true>, CGAL::Triangulation_ds_vertex_base_2<CGAL::Triangulation_data_structure_2<CGAL::Triangulation_vertex_base_with_info_2<unsigned long, CGAL::Projection_traits_3<CGAL::Epeck, true>, CGAL::Triangulation_vertex_base_2<CGAL::Projection_traits_3<CGAL::Epeck, true>, CGAL::Triangulation_ds_vertex_base_2>>, CGAL::Constrained_triangulation_face_base_2<CGAL::Projection_traits_3<CGAL::Epeck, true>, CGAL::Triangulation_face_base_2<CGAL::Projection_traits_3<CGAL::Epeck, true>, CGAL::Triangulation_ds_face_base_2>>>>>>, CGAL::Default, CGAL::Default, CGAL::Default>, false>, CGAL::internal::CC_iterator<CGAL::Compact_container<CGAL::Triangulation_vertex_base_with_info_2<unsigned long, CGAL::Projection_traits_3<CGAL::Epeck, true>, CGAL::Triangulation_vertex_base_2<CGAL::Projection_traits_3<CGAL::Epeck, true>, CGAL::Triangulation_ds_vertex_base_2<CGAL::Triangulation_data_structure_2<CGAL::Triangulation_vertex_base_with_info_2<unsigned long, CGAL::Projection_traits_3<CGAL::Epeck, true>, CGAL::Triangulation_vertex_base_2<CGAL::Projection_traits_3<CGAL::Epeck, true>, CGAL::Triangulation_ds_vertex_base_2>>, CGAL::Constrained_triangulation_face_base_2<CGAL::Projection_traits_3<CGAL::Epeck, true>, CGAL::Triangulation_face_base_2<CGAL::Projection_traits_3<CGAL::Epeck, true>, CGAL::Triangulation_ds_face_base_2>>>>>>, CGAL::Default, CGAL::Default, CGAL::Default>, false>) + 276
11 BambuStudio 0x105caa304 <deduplicated_symbol> + 324
12 BambuStudio 0x105ca7d10 void CGAL::Polygon_mesh_processing::Corefinement::Surface_intersection_visitor_for_corefinement<CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >, CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >::Property_map<CGAL::SM_Vertex_index, CGAL::Point_3CGAL::Epick >, CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >::Property_map<CGAL::SM_Vertex_index, CGAL::Point_3CGAL::Epick >, CGAL::Polygon_mesh_processing::Corefinement::No_extra_output_from_corefinement<CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >>, CGAL::Polygon_mesh_processing::Corefinement::Ecm_bind<CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >, CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >::Property_map<CGAL::SM_Edge_index, bool>, CGAL::Polygon_mesh_processing::Corefinement::No_mark<CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >>>, priv::Visitor, false, false>::triangulate_intersected_faces<std::__1::__map_iterator<std::__1::__tree_iterator<std::__1::__value_type<CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >, boost::unordered::unordered_map<CGAL::SM_Face_index, std::__1::vector<unsigned long, std::__1::allocator>, boost::hashCGAL::SM_Face_index , std::__1::equal_toCGAL::SM_Face_index , std::__1::allocator<std::__1::pair<CGAL::SM_Face_index const, std::__1::vector<unsigned long, std::__1::allocator>>>>>, std::__1::__tree_node<std::__1::__value_type<CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick > , boost::unordered::unordered_map<CGAL::SM_Face_index, std::__1::vector<unsigned long, std::__1::allocator>, boost::hashCGAL::SM_Face_index , std::__1::equal_toCGAL::SM_Face_index , std::__1::allocator<std::__1::pair<CGAL::SM_Face_index const, std::__1::vector<unsigned long, std::__1::allocator>>>>>, void*>, long>>, CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >::Property_map<CGAL::SM_Vertex_index, CGAL::Point_3CGAL::Epick >>(std::__1::__map_iterator<std::__1::__tree_iterator<std::__1::__value_type<CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick > , boost::unordered::unordered_map<CGAL::SM_Face_index, std::__1::vector<unsigned long, std::__1::allocator>, boost::hashCGAL::SM_Face_index , std::__1::equal_toCGAL::SM_Face_index , std::__1::allocator<std::__1::pair<CGAL::SM_Face_index const, std::__1::vector<unsigned long, std::__1::allocator>>>>>, std::__1::__tree_node<std::__1::__value_type<CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >, boost::unordered::unordered_map<CGAL::SM_Face_index, std::__1::vector<unsigned long, std::__1::allocator>, boost::hashCGAL::SM_Face_index , std::__1::equal_toCGAL::SM_Face_index , std::__1::allocator<std::__1::pair<CGAL::SM_Face_index const, std::__1::vector<unsigned long, std::__1::allocator>>>>>, void >, long>>, CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >::Property_map<CGAL::SM_Vertex_index, CGAL::Point_3CGAL::Epick > const&, CGAL::Polygon_mesh_processing::Corefinement::Intersection_nodes<CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >, CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >::Property_map<CGAL::SM_Vertex_index, CGAL::Point_3CGAL::Epick >, CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >::Property_map<CGAL::SM_Vertex_index, CGAL::Point_3CGAL::Epick >, true, false>&, std::__1::map<CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick > , boost::unordered::unordered_map<CGAL::SM_Face_index, CGAL::Polygon_mesh_processing::Corefinement::Surface_intersection_visitor_for_corefinement<CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >, CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >::Property_map<CGAL::SM_Vertex_index, CGAL::Point_3CGAL::Epick >, CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >::Property_map<CGAL::SM_Vertex_index, CGAL::Point_3CGAL::Epick >, CGAL::Polygon_mesh_processing::Corefinement::No_extra_output_from_corefinement<CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >>, CGAL::Polygon_mesh_processing::Corefinement::Ecm_bind<CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >, CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >::Property_map<CGAL::SM_Edge_index, bool>, CGAL::Polygon_mesh_processing::Corefinement::No_mark<CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >>>, priv::Visitor, false, false>::Face_boundary, boost::hashCGAL::SM_Face_index , std::__1::equal_toCGAL::SM_Face_index , std::__1::allocator<std::__1::pair<CGAL::SM_Face_index const, CGAL::Polygon_mesh_processing::Corefinement::Surface_intersection_visitor_for_corefinement<CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >, CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >::Property_map<CGAL::SM_Vertex_index, CGAL::Point_3CGAL::Epick >, CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >::Property_map<CGAL::SM_Vertex_index, CGAL::Point_3CGAL::Epick >, CGAL::Polygon_mesh_processing::Corefinement::No_extra_output_from_corefinement<CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >>, CGAL::Polygon_mesh_processing::Corefinement::Ecm_bind<CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >, CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >::Property_map<CGAL::SM_Edge_index, bool>, CGAL::Polygon_mesh_processing::Corefinement::No_mark<CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >>>, priv::Visitor, false, false>::Face_boundary>>>, std::__1::less<CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >>, std::__1::allocator<std::__1::pair<CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick > const, boost::unordered::unordered_map<CGAL::SM_Face_index, CGAL::Polygon_mesh_processing::Corefinement::Surface_intersection_visitor_for_corefinement<CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >, CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >::Property_map<CGAL::SM_Vertex_index, CGAL::Point_3CGAL::Epick >, CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >::Property_map<CGAL::SM_Vertex_index, CGAL::Point_3CGAL::Epick >, CGAL::Polygon_mesh_processing::Corefinement::No_extra_output_from_corefinement<CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >>, CGAL::Polygon_mesh_processing::Corefinement::Ecm_bind<CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >, CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >::Property_map<CGAL::SM_Edge_index, bool>, CGAL::Polygon_mesh_processing::Corefinement::No_mark<CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >>>, priv::Visitor, false, false>::Face_boundary, boost::hashCGAL::SM_Face_index , std::__1::equal_toCGAL::SM_Face_index , std::__1::allocator<std::__1::pair<CGAL::SM_Face_index const, CGAL::Polygon_mesh_processing::Corefinement::Surface_intersection_visitor_for_corefinement<CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >, CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >::Property_map<CGAL::SM_Vertex_index, CGAL::Point_3CGAL::Epick >, CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >::Property_map<CGAL::SM_Vertex_index, CGAL::Point_3CGAL::Epick >, CGAL::Polygon_mesh_processing::Corefinement::No_extra_output_from_corefinement<CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >>, CGAL::Polygon_mesh_processing::Corefinement::Ecm_bind<CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >, CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >::Property_map<CGAL::SM_Edge_index, bool>, CGAL::Polygon_mesh_processing::Corefinement::No_mark<CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >>>, priv::Visitor, false, false>::Face_boundary>>>>>>&) + 5804
13 BambuStudio 0x105ca12dc CGAL::Polygon_mesh_processing::Corefinement::Surface_intersection_visitor_for_corefinement<CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >, CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >::Property_map<CGAL::SM_Vertex_index, CGAL::Point_3CGAL::Epick >, CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >::Property_map<CGAL::SM_Vertex_index, CGAL::Point_3CGAL::Epick >, CGAL::Polygon_mesh_processing::Corefinement::No_extra_output_from_corefinement<CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >>, CGAL::Polygon_mesh_processing::Corefinement::Ecm_bind<CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >, CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >::Property_map<CGAL::SM_Edge_index, bool>, CGAL::Polygon_mesh_processing::Corefinement::No_mark<CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >>>, priv::Visitor, false, false>::finalize(CGAL::Polygon_mesh_processing::Corefinement::Intersection_nodes<CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >, CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >::Property_map<CGAL::SM_Vertex_index, CGAL::Point_3CGAL::Epick >, CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >::Property_map<CGAL::SM_Vertex_index, CGAL::Point_3CGAL::Epick >, true, false>&, CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick > const&, CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick > const&, CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >::Property_map<CGAL::SM_Vertex_index, CGAL::Point_3CGAL::Epick > const&, CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >::Property_map<CGAL::SM_Vertex_index, CGAL::Point_3CGAL::Epick > const&) + 1328
14 BambuStudio 0x105c9d658 CGAL::Emptyset_iterator CGAL::Polygon_mesh_processing::Corefinement::Intersection_of_triangle_meshes<CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >, CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >::Property_map<CGAL::SM_Vertex_index, CGAL::Point_3CGAL::Epick >, CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >::Property_map<CGAL::SM_Vertex_index, CGAL::Point_3CGAL::Epick >, CGAL::Polygon_mesh_processing::Corefinement::Surface_intersection_visitor_for_corefinement<CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >, CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >::Property_map<CGAL::SM_Vertex_index, CGAL::Point_3CGAL::Epick >, CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >::Property_map<CGAL::SM_Vertex_index, CGAL::Point_3CGAL::Epick >, CGAL::Polygon_mesh_processing::Corefinement::No_extra_output_from_corefinement<CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >>, CGAL::Polygon_mesh_processing::Corefinement::Ecm_bind<CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >, CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >::Property_map<CGAL::SM_Edge_index, bool>, CGAL::Polygon_mesh_processing::Corefinement::No_mark<CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >>>, priv::Visitor, false, false>>::operator()CGAL::Emptyset_iterator (CGAL::Emptyset_iterator, bool, bool) + 448
15 BambuStudio 0x105c8ae3c void CGAL::Polygon_mesh_processing::corefine<CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >, CGAL::Named_function_parameters<bool, CGAL::internal_np::throw_on_self_intersection_t, CGAL::Named_function_parameters<CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >::Property_map<CGAL::SM_Edge_index, bool>, CGAL::internal_np::edge_is_constrained_t, CGAL::Named_function_parameters<priv::Visitor, CGAL::internal_np::visitor_t, CGAL::internal_np::No_property>>>, CGAL::Named_function_parameters<bool, CGAL::internal_np::do_not_modify_t, CGAL::internal_np::No_property>>(CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >&, CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >&, CGAL::Named_function_parameters<bool, CGAL::internal_np::throw_on_self_intersection_t, CGAL::Named_function_parameters<CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >::Property_map<CGAL::SM_Edge_index, bool>, CGAL::internal_np::edge_is_constrained_t, CGAL::Named_function_parameters<priv::Visitor, CGAL::internal_np::visitor_t, CGAL::internal_np::No_property>>> const&, CGAL::Named_function_parameters<bool, CGAL::internal_np::do_not_modify_t, CGAL::internal_np::No_property> const&) + 496
16 BambuStudio 0x105c83fd8 priv::cut_from_model(CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >&, std::__1::vector<Slic3r::ExPolygon, std::__1::allocatorSlic3r::ExPolygon > const&, CGAL::Surface_mesh<CGAL::Point_3CGAL::Epick >&, float, Slic3r::ExPolygonsIndices const&) + 1024
17 BambuStudio 0x105c81ea8 Slic3r::cut_surface(std::__1::vector<Slic3r::ExPolygon, std::__1::allocatorSlic3r::ExPolygon > const&, std::__1::vector<indexed_triangle_set, std::__1::allocator<indexed_triangle_set>> const&, Slic3r::Emboss::IProjection const&, float) + 580
18 BambuStudio 0x10564a650 Slic3r::GUI::Emboss::cut_surface_to_its(std::__1::vector<Slic3r::ExPolygon, std::__1::allocatorSlic3r::ExPolygon > const&, float, Eigen::Transform<double, 3, 2, 2> const&, std::__1::vector<Slic3r::GUI::Emboss::SurfaceVolumeData::ModelSource, std::__1::allocatorSlic3r::GUI::Emboss::SurfaceVolumeData::ModelSource > const&, Slic3r::GUI::Emboss::DataBase&) + 5004
19 BambuStudio 0x10563c1e0 Slic3r::GUI::Emboss::cut_surface(Slic3r::GUI::Emboss::DataBase&, Slic3r::GUI::Emboss::SurfaceVolumeData const&) + 1760
20 BambuStudio 0x10563b950 Slic3r::GUI::Emboss::UpdateSurfaceVolumeJob::process(Slic3r::GUI::JobNew::Ctl&) + 112
21 BambuStudio 0x1051d04f4 Slic3r::GUI::PlaterWorkerSlic3r::GUI::BoostThreadWorker ::PlaterJob::process(Slic3r::GUI::JobNew::Ctl&) + 276
22 BambuStudio 0x1056366d4 Slic3r::GUI::BoostThreadWorker::run() + 444
23 BambuStudio 0x105c069b0 boost::(anonymous namespace)::thread_proxy(void*) + 176
24 libsystem_pthread.dylib 0x1863d7c0c _pthread_start + 136
25 libsystem_pthread.dylib 0x1863d2b80 thread_start + 8
Qjo
January 3, 2026, 12:39pm
2
I had a similar issue a while back. Bambu studio crashes when adding negative part modifier SVG to model · Issue #5995 · bambulab/BambuStudio · GitHub
You could try to reopen this one or start a new issue. Seems like the same thing.
I’m on a M2 PRO with macOS Tahoe 26.3, running current Bambu Studio build. I have the same thing happen every time I try to add a logo to a cylinder. Sometimes it crashes while I’m adjusting size and sometimes it won’t. However, it always crashes when I check the use surface box.
I’m also having this exact same problem. When I add an svg modifier, I can move and resize it but as soon as I click the use surface box, Bambu Studio crashes every time.
Mac Crash Workaround – “Use Surface” with SVG on Curved Models
I wanted to share a workaround I found in case anyone else is experiencing this issue.
Issue:
On my MacBook Pro (Apple M1 Pro) , both Bambu Studio and OrcaSlicer crash immediately when I use Use Surface on a curved model after selecting an SVG.
At first I thought it was a Bambu Studio bug, but I was able to reproduce the exact same crash in OrcaSlicer, which makes me think it may be related to a shared geometry/mesh processing library rather than either slicer specifically.
Workaround that consistently works for me:
Scale the model up to 200% (or larger).
Apply the SVG using Use Surface .
Finish positioning/editing the SVG.
Scale the model back down to its original size.
I’ve repeated this several times, and it has worked every time. At the original scale, the application crashes immediately. At 200%, the projection completes successfully, and I can safely scale the model back down afterward.
Hopefully this helps someone else while the underlying issue is investigated.
System:
If anyone else can test this on Apple Silicon or Intel Macs, I’d be interested to know if you get the same results.
Hello, I tried this method and on the first try… Bambu Studio crashed….
Macbook Pro 16” M4 Pro… I think Im gonna download Bambu Studio on my Parallels Windows 10. And I’ll come report my findings. This is driving me crazy… I’ve blamed the svg, I’ve created it manually on Inkscape in the most clean way, and still crashes, in Orcaslicer too… BBL
Ok… I got some good and bad news. Installing Bambu Studio inside a windows emulation works but… the good news is that I managed to get my cleanest-of-them-all SVG to use surface on 2 sides of my box. The bad news is that on the third side it crashes all the time I press “use surface”. Maybe it has to do with our Silicon chips. I dont see any Intel-based mac users saying they have this problem. I dont know I feel bad I cannot use svgs other than text on my stuff.
Ok please excuse me if this looks like spam but I’m working as I go here.
I managed to cover my entire box with the (kinda) same svg. I did as follows:
I scaled my svg in Inkscape to 300x400, formerly I had it at 3000x4000.
I used Bambu Labs on my windows Parallels emulation.
I imported the svg on EACH face I wanted the texture. It never crashed.
Do not try to copy paste the svg, import it for each face. I dont know If I was lucky but this is the workflow I had. I never could put an svg on multiple faces. I hope it helps.
