Bambu Studio crashes after slicing – solved (NVIDIA problem)
I had a problem with Bambu Studio crashing every time after slicing for large models. I have an NVIDIA graphics adapter, and I found a driver setting that got rid of the problem – now it never crashes even for very large models.
The setting is called “Threaded optimization” and you have to turn it Off.
There are several ways to apply this setting under the NVIDIA Control Panel. One can do it globally for all programs, but I choose to do it only for Bambu Studio. In the NVIDIA Control Panel, go to “3D Settings → Manage 3D Settings → Program Settings” and add Bambu Studio to the program list (if it is not already there). Locate the setting called “Threaded optimization” and turn it Off.
//Henrik
Thank you!!! This fixed the crashing I was having on a fairly simple model that I was slicing in vase mode. Never would have thought it could be NVIDIA related.
I’m glad it helped!
//Henrik
Grateful thank you from me as well - was completely unable to do anything useful with Bambu Studio 2 (with new H2D) as it crashed on 90% of slice/send operations. The NVIDIA settings change fixed it immediately, much more helpful than the support response I had.
Good to hear! I have notice some stability issues lately with Fusion 360 when running simultaneously with Bambu Studio, I don´t know if it is related to the driver setting. But Bambu Studio still works fine all the time.
//Henrik
Man, this just took away all of my frustration. I had to keep going to my MacBook to slice files; it was a pain. Thank you.
Thanks for documenting this!
Using BBL Studio while we wait for Orca to be H2D-ready & was becoming very frustrated with the instability on my workstation, especially when it worked okay on my old (slow) box.
You saved my sanity… or at least the small amount I have remaining.
@henrike586
Thanks, it also helped my i9, 64 GB NVidia powered machine…
Threaded Optimization: OFF
However , this should be addressed by the SW developer of BambuStudio… as it looks like it is an old / badly adopted GPL engine with not thread-safe way of programming…
Kr
Mike
Mike, you are absolutely right - the problem is most likely within Bambu Studio, the driver setting just cover it up. I will notify the support about this, maybe it can help them find a real solution.
Thanks
//Henrik
Don’t know if it’s related, but I opened this issue on their github back in April 2023 and they said it’s a known problem:
Bambu Studio crashes hard when using camera view and RTX 3070 Ti Laptop GPU · Issue #1648 · bambulab/BambuStudio · GitHub
@sprior thanks for pointing this out, but I think the circumstances where the BS crashes are quite different. But who knows, it might be the same underlying cause.
//Henrik
Thank you very much, the fix worked for me. No crash since I changed my settings as suggested.
I contacted Bambu support about this issue. They said that they are working on a solution, and they will tell us in the release notes when it is done.
//Henrik
THANK YOU Henrike! I was getting really frustrated!
It might be worth giving it a try, but I had this problem every time I went to slice a print. However, I then saw a post that suggested updating my BIOS for my motherboard. I did that and have not had an issue since.
Thank you so much for posting this! I am curious, how did you figure out that was the issue? I’d love to learn how to troubleshoot issues like this myself.
Quite a bit of luck I guess - I have a background as a programmer, and I got the feeling this problem was related to the graphic rendering. Since the NVIDIA driver settings is quite easy to access, I just started changing one setting at a time. After a couple of tries I found the right one. It is no guarantee this method works for every graphics related problem, it was just a bit of luck.
//Henrik
Thank you so much i was going nutz until your post solved my issues!
For me, this didn’t work. I tried this along with several other MS Windows or Nvidia configuration fixes suggested by people, and nothing worked. So I decided to go one by one in the process settings to see which modification I was doing that was causing it to fail. There turned out to be several.
  1. I was doing a Top Z distance and Bottom Z distance of 0. I’m using dissolvable supports so it’s fine. And the weird part is on other builds it allowed me to do zero without issue. I changed it to 0.1 and that allowed it to slice.
  2. I had disabled the prime tower - crash. I enabled it, and it sliced fine.
So that would be another route to take if OS configuration changes don’t work for you. Reset your process settings to the defaults, and then go one by one, slicing after each change, to find the one(s) that are causing it to crash.
