Bambu Studio delivers strange results
I found a relief picture of the hulkbuster on thingiverse that I wanted to print out for my grandson.
when I slice this in bambu studio, I get the highlighted outlines just as individual dots and not a continuous line, which doesn’t look great as a result. I made a comparison with the Prusa slicer, there these structures are neatly displayed.
With this structural image, a color change is necessary after the base area so that the image stands out from the background. In the bamboo slicer, however, it looks very interrupted.
Do I have setting options there that I haven’t found yet?
Wird hochgeladen: bambu studio.jpg …
Wird hochgeladen: prusa slicer.jpg …
Can’t open the images for some reason. Maybe can you try to edit your post and include it again?
Hello paulocoelhojr,
thanks for the hint.
uploading the images should now have worked.
:wink:
After slicing, turn off the seam display. Does that look better?
unfortunately no, the sliced view is still very uneven.
Arachne wall generator does a better job, but the model is just crappy. even on 0.08 arachne the result is not good. maybe try slycing it in cura, as the author had success there.
And i suggest switching to OrcaSlicer instead of BS, there you got proper build in calibration, less hidden settings, arachne + overhand slowdown, etc.
0.08
0.2
in comparision to the raw model
since i had some time to hand, i redid the model from a picture i found.
source picture
with a lot better results
https://www.printables.com/de/model/528998-hulkbuster-blueprint
Hello ZundersHD,
Thank you for doing this extra work. I also tried to get a reasonable result in the Orca slicer but that didn’t work, so I printed the file with my Prusa MK3s, it took longer but the result is what I expected.
greet Guenter
