Bambu Studio does not display X1C Bed Temp Version 1.10.0.89. Current bed temp is empty, but dest temp is OK.
What plate type is selected in Bambu Studio?
Textured PEI Plate. Latest Beta did not display Nozzle Dest Temp or Bed Dest Temp. They were always blank. I have plate checking turned off, since I would get an error almost every run.
Maybe a bug possibly. After updating today I noticed similar issue, sometimes the bed and extruder temps disappear or just don’t show up. Also the little colored filament lines showing which filament is currently printing, and where in the swap they are don’t update unless I switch tabs.
I’ll give that a try.
tnx
I did a full recalibrate. The display was then correct. I started a print job and the display was then incorrect with the current bed temp… Dest temp was OK.
I started a new project, did a build with the new Bambu Studio, and the nozzle and the nozzle and bed temps both seem to be displaying correctly.
I am getting this now too where the temps or progress/status isn’t displaying on the X1C printer display. Had it two times so far… and have to start over by shutting it off and turning it back on to get this to start working again. Also have seen this with both the textured plate and cool plate. Not sure if this is a new defect or my printer has a hardware malfunction (less than a year old).
What version of Studio are you using? For most of us, the problem was corrected quickly by Bambu with their 1.10.1.50 release.
I have been using 1.10.1.50 since it was released. So I have no idea if this is a new bug or a hardware issue but this happened to me twice with the second time being today.
