Bambu Studio "Failed to download the [network] plug-in" on Linux
Running Bambu Studio latest version 01.10.02.76 (Fedora flavor).
On ARCHLINUX (AMD64, not ARM), fully-up-to-date.
At startup time, the network plugin is NOT downloaded anymore (it was working fine with all previous versions).
Error is :
About :
And yes i do know that link (in the error box : Failed to Get Network Plugin | Bambu Lab Wiki), but there is nothing at all related to this issue (and i have 0 network issue, no VPN activated, no firewall issue).
Also there is nothing at all in the console (when launching bambu studio from a terminal).
Not sure on this one sorry, it might be worth asking Bambu support but they are not very good :laughing: !
Thanks,
OTpandy1
Happy Printing!
Today I got exactly the same error for this version of Bambulab when installing the latest version. I run MacOS Sequoia 15.3.1 and also no VPN running whatsoever. Looked through all the things from the wiki but to no avail. HOW?!!!
Any updates on this topic?
Not on my side - i tried many things (like trying to manually downloading the plugin, …) but without any success.
For now i reverted to the previous Bambu Studio version, as for this one, the plugin is already cached in local for me, so it’s still working (at least for the moment).
I also reverted to a previous version and it works again. I also submitted a ticket and got a reply that I had to revert to older version and that they are aware of the problem and working on a fix :wink:
Still the exact same error with Bambu Studio v02.00.03.54 (latest public release), both FEDORA or UBUNTU flavor.
Any ideas ?!
It seems that with latest firmware, the latest bambu studio is now mandatory, but if i can’t have the network plugin, it really going to be a blocker.
Ok it litteraly took me hours to understand how to manually download the plugin (many informations are missing on the wiki), but in the end, what needs to be done is :
VERSION="02.00.03.54"
SHORT_VERSION=$(echo "$VERSION" | sed 's/\([0-9][0-9]\.[0-9][0-9]\.[0-9][0-9]\).*/\1.00/')
echo "Bambu Studio [$VERSION], expected API version [$SHORT_VERSION]"
curl -sL "https://api.bambulab.com/v1/iot-service/api/slicer/resource?slicer/plugins/cloud=$SHORT_VERSION"|jq ".resources[0].url"|read URL
LINUX_URL=$(echo "$URL" | sed -e 's/win_/linux_/' -e 's/"//g')
echo "Identified LINUX URL [$LINUX_URL]"
cd ~/.config/BambuStudio/plugins
wget --quiet "$LINUX_URL" -O bambu-linux-network-plugin.zip
unzip -o bambu-linux-network-plugin.zip
rm -f bambu-linux-network-plugin.zip >/dev/null 2>&1
ls -Al
Then the resulting result is :
~/.config/BambuStudio/plugins% ll
total 18M
drwxr-xr-x 2 sergio sergio 4.0K 2025-05-01 14:42 backup
-rw-rw-r-- 1 sergio sergio 6.5M 2025-04-22 11:02 libBambuSource.so
-rw-rw-r-- 1 sergio sergio 4.6M 2025-04-22 11:02 libbambu_networking.so
-rw-rw-r-- 1 sergio sergio 6.7M 2025-04-22 11:02 liblive555.so
And from there, the latest Bambu Studio version is now working fine … (network plugin activated, login working, etc.)
this works, thanks.
Just the “jq ".resources[0].url” didn’t work. had to extract the link by hand from the json.
But: for me the folder was: ~/.config/BambuStudioInternal/plugins (plugins was not there, had to create it and put libs here)
Maybe this is because I installed Bambulab Studio from source, idk.
So if you follow the code above and you don’t have ~/.config/BambuStudio/plugins , then check if you have ~/.config/BambuStudioInternal/ - if so create the plugins there.
Ok I.m trying to figure out how to get this to work. I was able to download and install the the studio using Linux, and as stated here I do have issues with he network plug in. Can I get a step by step how to get this fixed? I don’t know much about this so if you need more infor let me know.
