It’s probably been discussed before, but I just recently learned it. The “calibrations” button is missing at the top of Bambu Studio and I was limited to just 2 flow calibrations. I read somewhere, maybe here, but there is a sorta hack to enable the old calibration button. You go to your computer’s display settings and change the “scale” and after you do that go back into Bambu Studio and presto the calibration button with ALL the calibrations is there. Start your test and utilize your findings. You will have to cycle back and forth to the display scale as the button will disappear each time you run the test.
It might be an H2 series printer anomaly? I’m using windows and do not have it. I used to have the calibration button back when I had an A1 printer. I’m not sure.
Top-line Calibration is always available here.
Windows 11
Studio 2.3.0.70
48 inch 4K display
Scale 100% to 350%
All Bambu printers
You can simply enable developer mode in the settings, and calibrations will become available.
Thats exactly what I needed.
