Bambu Studio lost all my configuration since my last update
Bambu studio lost all my configuration since the last update
I have try adding printers or filament, bot nothing work.
If i try to load old configuration, i have an error message
Olivier
I can confirm that none of the configurations are loaded into the software on the Mac version either.
These are still present in the config directory.
I had the same and also a lot of others. Also the printer itself was gone and no chance to reconnect it. Only solution was to deinstall the new version and reinstall the old version.
I also have same issue.
Same to me. Installed the older version and everything is OK again.
Please update :slight_smile:
it is same for me and when i want to print a model i have this G-code error
HI
we have the same error and others…
PLA PRINT 2 HOURS > PETG CF BAMBU 12 HOURS !
Amazing !
Impossible to work
Thanks Bambu
Same hier, App Crashes after accesing Calibration Data, and restarts without Printer.
Switched to Orca Slicer to continue, or print from Makerworld.com
My X1C and Studio both updated today. I did not have to do the usual logout/login dance, all my filament and process profiles are available and I’ve had no issues printing.
Windows 11
X1C Firmware 01.06.05.01
Bambu Studio 1.7.6.92
I do have a display issue, but need to investigate further…
I recently did the update and my Bambu studio lost all my configuration. now i can’t figure out the new printer lay out.
How do I deinstall the new version and reinstall the old version? I am having the same issue since I updated on yesterday 5/9/2025. I don’t remember the old version.
I just up dated the TPU filament popup and lost everything.
I have V1.10.1.50
I logged out, then in, didn’t help.
To select a printer, it doesn’t show Bambu printers, 50 others.
Having the same problem. I’m 13, can you please tell me how to install an old version?
how do you find the install info for the old version? can you send a link?
my configuration files were also completely gone. but im pretty sure i found a solution. im not sure if it will work for others, but it worked for me.
i did this on bambu studio, not bambu handy.
i own a bambu labs a1 and an ams lite.
i simply logged out of makerworld and logged back in. this seemed to take the configuration files from my account cloud to bambu studio. this is because bambu studio stores the configuration files in your makerworld account too.
hope this helped!!
(also to anyone who is having trouble with this, i wish you the best of luck.)
I edit my post in order to bring some value and not only complain :
Config files are preserved but 2.6 alpha does not read them. Probably due to alpha nature, it stays away from stable release configs ?
I rolled-back to 2.5. Find official release on their github .
2.5.3 : Release 2.5.3 Public Release · bambulab/BambuStudio · GitHub
Make sure you get only from their github.
All configs are present.
I would suggest bambu to NOT replace the stable studio software when installing an alpha.
Prusa has alphas/betas installed ALONG stable release and it considered a secondary program.
