The following guide presents the process of using the Multi-Plate function available with Bambu Studio and X1 series.
Did you ever use this function? If so, do you have any suggestions to further improve it?
I wanted to use this, but didn’t find out how it worked at the time: send several discs to the printer and then print them out one after the other.
However, I find this somewhat cumbersome:
When performing multi-plate printing, typically the first model printed is the last model added . Therefore, the print order should be based on the order in which the print plate are added, i.e., the plate that is added first will be printed later. This order helps to ensure that the model is assembled and spliced correctly.
I thought the discs would go in order (1,2,3,4,5…).
