Including pictures and detailed information about the print speeds, filament type and settings used will help get the appropriate solutions.
Hi Team,
I am trying to use eSun PLA+ but the Aux fan is causing severe warping, how do I turn this off using slicer settings.
I have created a User Preset called eSun PLA Plus but whenever I send a print to the printer it ignores my settings and uses default for eSun PLA. I have turned the aux fan down to 15% and am trying to use 60degrees for bed temp.
The only way I can print eSun PLA + is by waiting for the first layer to go down then manually turning off the aux fan. This is rather cumbersome and tedius.
Yes Orca slicer is way of the force for Bambu printers
Usually does not ignore your settings , but take a look in the Advanced tab which will overwrite some of the Fan speeds and may need changing the G-CODE
Not confident if the Aux fan is the main reason , but if it works for you than the above should help
i print eSUN PLA very often with open door and fan off (manually turning it off after the 2nd layer) , more likely flow/K and other settings . Moisture not a problem usually, but i have seen many time with my eSUN PLA+ and drying helps
In some models warping have been a problem for me as well and change the cooling for that print only ensuring that filament is dry and if that doe snot help print it with non-bambu printer MK4 or MK3S
Here are my some settings, i have 3 or 4 profiles for eSUN PLA+ , with minor differences and very often when i get a new batch need to be fine tuned again
Wet eSUN PLA+ or not fine tune also causes warping in some models ( note that from eSUN out of the box very often come wet enough for some prints
