So I’m trying to print a floating V-shape which connects to the main print at a much higher layer. When using the automatic tree it puts support underneath, however the connection fails and the part comes loose after a few layers (blue line bellow).
No problem and logical due to the small contact surface. So I’ve used the support painter to place an additional support a few layers up.
However, it refuses to create a support at the painted line. It does create one for the small painted section on top of the opening above it.
When changing to manual it does use it, but then I need to create every support.
Any suggestions why it doesn’t place the support as indicated by the paint tool?
(For those wondering: it’s a garden lamp)
