Hello! How to get sharp, nice and clean edges with bambu lab p1p? In the picture blue one flower ir sprinted with bambu lab but beige flower with enderr 3v2. both used a 0.4 noozle.
If I had to guess, you’re filament isn’t tuned to the correct parameters. The stringing and over-extrusion is what leads me to believe this is the case. But you’ll have to investigate this further. Also, you did not mention which filament you’re using and also, to fully diagnose something and rule out the filament versus the settings, you’ll want to print the same model using the same filament on both printers.
You may find it easier to switch to Orca Slicer which is a fork/clone of Bambu Slicer with baked-in calibration functions.
Here’s their tutorial but admittedly, the verbiage is pretty dense reading.
Here’s a couple YouTube tutorials which I found to be really good at better explaining the text in the link above.
This is an older one from ButterPocketPrints
Here he dials-in directly on how to do it for Bambu
And this is more generic but covers Max Volumetric Flow Rate which can be a contributing factory in the results you’re seeing in the photo you incldued.
