Bambu Studio strange circles in negative parts for holes
So im new in the 3D print world and im getting started, I created un Fusion 360 some coins that im trying to put inside a hole for a NFC tag inside the coin, just export the piece in stl to bambu studio and in bambu im trying to do the hole for the nfc tag (creating a negative part i put the nfc measures and just merge it with the piece) i dont know why is creating a white circle o white wall around the hole when the whole coin is blue i dont know if someone can tell me why is this happening.Video Problem Demostration
I don’t run files from people’s posts generally but bet you are seeing filament type in the preview and support might be filling holes. You can view the sliced model as filament color or as color coded for what kind of line it is - infill, wall, overhang, support, etc. Dropdown in the upper right to select.
If you’re getting support in holes it’s a setting either global or for a particular piece but it could be support is needed for your model. You can enforce or block support with various shapes if you right click on the part you want to add modifiers to, pick the modifier and place. They size and move with the regular widgets you use to size and move your model.
So the problem that I was having was that I was using the Fill Paint and painting the piece in green but in the object list it appears that its main color was brown, but its adding like an oval structure in a keychain hole that I added using a negative part… and i dont understand why…
