Bambu Studio
How about a way to cut and paste or drag objects from one project to another??-- in Bambu Studio-when multiple project windows are open
You can do this among multiple plates in a single project - perhaps that’s something you can use? Each plate gets sliced and printed separately.
I want to move things from project to project…have not found a way to do ti
Export the objects you want to move as an STL file. You can then import the STL into the other project
How do i export one object-- I get all of the project in the file when I select only one
Thanks
Sorry I missed your reply. I hope you found the anwer by now, but if not:
To export just a single model a STL, click on a model so the single model is highlighted by the bounding box (you may have to set Object mode in the left panel)
Right Click on it and Select Export as STL
got it, thanks, I am really looking for a drag and drop way to move .stl objects from one project to another when multiple projects are open.
Yeah, I want this too. Having to export/import is awkward.
One thing to check is to see if PrusaSlicer has this feature. Since Bambu Studio is a fork of that project, this would indicate that a particular feature should be portable or not. I can see Bambu not wanting to make modifications to PrusaSlicer that aren’t directly related to the product, as that would create a pretty serious divergence, which in my experience causes one to have a Bad Time.
Yes! This is very much needed!
If you export to STL you loose all the coloring, which makes that option useless.
So either allow copy and paste between projects or provide model export with color.
It also makes it hard to manage objects that are designed in one plate to be reused in other plates, especially with boolean modifiers.
Hello Guys, is there a way in Bambu Studio to easy Assemble parts and align them parallel (like in Solidworks - linking two surfaces) after cutting parts? Atm i have to move them slowly together and check every 0,01 if the parts are parallel.
The lack of copy/paste is frustrating. Feels like 1995 in here.
2 1/2 years later, would still like to have this usability feature implemented :upside_down_face: :slightly_smiling_face:
Came here 23 days later to say the same. Really need this.
The import 3mf (geometry only) from another project is a great way to bring objects over with the colors. You’ll have to remove the extra objects you don’t need but it’s much easier than having to recolor an stl file. a copy/paste feature CTRL+C, CTRL+V only works within the same project but it would be nice to have across projects. This is a good workaround though.
