Ok - Love the printer- been flawless from a 3D printer standpoint. I just started using the Cutting module this evening. Long time Silhouette user so I’m fairly familiar with the workflow of cutting / plotting.
I know the software is new, but it’s fairly basic in it’s current form. What I cannot seem to figure out is the Print Then Cut feature. I import a graphic object fine, I set the object to print then cut. In the preview, everything looks great and the cut line is in the proper spot. Now I need to print the sheet so I can place it on the cut bed.
----- How do you print out of this software? ----
I cannot find anywhere to set up a local inkjet printer to send the “print” part of the process to. There are no setup options for 2d printers, no shortcut keys, etc etc. If I have to print from an external source, all I can figure out is to import a snapshot from the birdseye camera and try to manually place a cut line - which is messy and not accurate.
Is this process different in Bambu Suite? It’s been a standard issue feature in other cutters since… forever?
THANK YOU for the link. I will say it’s a very bizarre workflow, but I am glad it was user error and not the software. I will play around with this tonight and see how it goes.
i tried to create a topic but it wont let me. i would like to know when they will add the abbility to make grid lines to place multiple images accuratly.
i am trying to print 12 business cards on a plate and the auto batch doesnt reconize the 12 cards for auto placement so i need to do it manualy but its hard to place all 12 cards by eye i would need to be able to place a grid pattern
