BAMBU X1 BRIDGE NYLON print Settings?
I have the BAMBU X1 with a Hardened Steel Extruder and hotend
, Can I print BRIDGE NYLON with this setup? and of so what print settings should I use?
I had not seen this before, but Taulman’s description makes it sound a lot like Bambu’s PAHT, though Bambu sells only a CF-filled version. I think you would be safe to start with the Bambu PAHT-CF preset, or there’s also ā€œGeneric PAā€. You will want to let the chamber heat up before starting the print (set the bed to 65C and let it run for a while), and follow Taulman’s advice on adhesive.
You should be able to do so. As a rule Bambu’s ā€œGenericā€ settings are pretty good, if a bit conservative.
Studio lets you edit the Filament’s settings here:
Edit Filament
You save like this: (EDITED)
So you can do some test prints and fine tune.
If you get SoftFever’s Bambu Studio ā€˜fork’ it has additional Calibrations not in Bambu’s Studio, like two click Temp Towers for a wide range of filaments, flow rate testing, pressure advance and more. Here’s his Wiki:
and the Main page which shows features, updates, and downloads:
Thank you all for the information. I did not want to try and run nylon without some advise.
I will give it a try and see what I can come up with
Thanks again! I am really enjoying my X1 printer. I have 5 other printers and they seem to be collecting dust now. The X1 has been great!
LOL! Yeah, I hear ya. My most used one a highly modded CR-10S is starting daggers at it.
