Bambulab A1 mini Axis Y squeek
Thank you so much. One of mine is squeaking and it looks like this will fix it.
I hope it helps! I received the loose y axis alert again and did end up slightly adjusting back in the other direction, but it is SO much quieter now. Hope this does help. It was frustrating because the prints were looking fine, I just wanted it to be as quiet as when I started printing with it. This seems to have done the trick.
For some reason, I can’t upload media here to show that in my accessory kit there is no grease, only oil (EU, A1 mini combo).
However, I tested first just moving the small sensor from the belt which was mentioned before and it helped and the prints comes out fine. I didn’t add any grease (have to get somewhere if the squeeking starts again).
Thank you!! Absolutly fixed it for me
