Bambulab H3C Supertac no adhesion whatsoever
Finally got my H3C today.
Started my first print and mehh.
When printing a pair of ball bearings, the PETG promptly lifted itself from the bed and stuck to the nozzle.
Printer is set to standard settings, Supertac plate is set in the printer.
Any ideas? Does your Supertac work? Used the textured PEI on my H2S, so I don’t have any experience with the Supertac plates.
Another user here received very wet filament with their printer. On a relative humidity test their spools are consistently in the 50s for %RH at room temperature. New filament can be very wet. It may not be, but it could be it’s just wet filament. Not sticking to build plates is a symptom of wet filament.
My supertac is working amazing. Everything sticks like glue. Even after it’s cooled down it’s a little bit tougher to remove parts then my Pei plate, not too hard. There’s a snap sound and all the parts release. Also make sure that you don’t wipe down the supertack with IPA. That being said like every other plate I buy before I even use it I wash it really good with a couple drops of dishwashing soap. Rub the soap with my hand very good. And then rinse it off extremely well with warm water.
Thanks for your answer.
Yeah, the filament seems to be pretty wet.
I just swapped out the filament used with one I just used in my H2S at 11% RH, same error.
Probably found the cause:
I’m mixing PLA and PETG on the first layer. PETG for the balls and PLA for the bearing housing.
I guess upping the plate temp might help with the PETG not sticking. The printer auto selected 60C for the first layer.
Yes if you mix the two you’re going to have issues lol. The temperatures will be different for the bed based on which filament you use. Also with any of my plates in between washings I will keep one side of the plate for PLA and the other side of the plate for PETG. If I print PETG on one side and then try to do another print on the same side with pla it doesn’t stick well. If I keep the sides separate I never have issues in between Washings. As long as I keep my hands off the plate I can go about 15 to 20 prints without having to wash it
