Hi. I got my H3C, and just started printing. I have a P2S aswell.
I have a project in bambulab studio that a share between these 2 printers. When switching between the 2 printers all the plates and object just fly around. You have too sync the filaments every time, it´s just a lot of hassle too get it right every time, it takes alot of time and the orgnization of the diffrent obejects is zero.
Could someone guide me how get this sorted?
Thanks, / Sam
Launch two instances of Studio and work with each of the printers using a separate instance of the program.
Hi thanks, ok I didnt try that, you have 2 bambulab windows open at the same time? Is it possible too share/ work in the same project that way?
Yes, that is perfectly possible. Each instance of the program is independent of the others. If they are connected to different printers (even if using the same account), there is nothing to prevent you from working on a single project across multiple instances of the BambuStudio.
You should try it yourself, and everything will become clear.
Thanks you! I will try this later today!!
