I load the TPU material, it recognizes it as TPU AMS, then it says unknown filament. If I select it manually, the error message shown in the picture appears. The other picture shows the current FW.
Usually, this problem occurs if the filament configuration profile is not installed in Bambu Studio
Please make sure you are running the latest version of Bambu Studio, and install the configuration update when the prompt shows up.
You can also enable the filament profile from the System Filaments tab.
Thanks a lot. I tried, it works well.
Still doesnât work for me, what else is there. Please update the software and fix this.
Welcome to the forum.
Have you installed the configuration update? There should be a prompt in the lower right hand corner of Bambu Studio
Is this fixed now for everyone having trouble?
I was about to hit the store button on âTPU for AMSâ, which is rather friggin expensive
butâŚ
It wasnât a problem to start, just a configuration that hadnât been set into the slicer.
It is a great material, I enjoy using it.
It is harder than the common 95A most assume is TPU, because they do not know TPU materials are actually points on a scale (shore hardness).
Its price and flexibility are equally between PLA and TPU 95A.
If your experience is 95A, this is harder and best considered a different material. It has new use cases.
The ability to print it in single and multiple colours at every layer is as easy as PLA.
It is far cheaper than TPU 95A HF from BL, although, BL is selling that at a massive mark-up.
Cool - the bump of this topic by stevegrimeszz made me think there was still some software issue. But since itâs working for you Iâll give it a shot.
I continue to have this problem. No update offered and I have tried multiple reboots and manually reupdated the firmware the latest versions. TPU for AMS does not appear in the list of system filaments. The only difference from other posters I can think of is that Iâm running BambuStudio on a MacBook.
Same issue here. It seems I can manually override the slow and filament setting to make things âworkâ. But it will not show up when i sync the filaments from the AMS even if the AMS at first properly detects the TPU for AMS roll.
Very frustrating. I donât see any configuration update to load in Bambu Studio, and there appears to be no firmware updates available.
Did you both see this yet? I donât know if Studio will auto-update to the latest version for you (it didnât for me but thatâs due to my own choices maybe).
Or, you could try OrcaSlicer⌠then again if you updated firmware⌠not sure if thatâll work anymore. (Ugh, this recent firmware controversy is messing everything upâŚ)
I know it doesnât help you, but it turned out that the filament works just fine in my own case. Itâs a pretty cool material option, I hope you get it working correctly.
Just a note orcaslicer release (at this time) wonât see it because the TPU configs havenât been rolled in. If you do run both orca and bambu, it will sometimes forget. Stay with just bambustudio for now. (or manually load the configs in orca if youâre up for that)
Please update and set the correct profile
