Mass-producing a single part — run 50× empty filament spools, brackets, organizers, or anything you’d normally have to babysit between prints
Overnight multi-model jobs — queue several different models into one job, hit send once, and let the printer chew through them while you’re asleep or away from the desk
Click here to show real printing demo GIF
Key features
No extra hardware needed — After each print, the printer automatically cools the bed using its built-in fans, then the nozzle head itself pushes the part off before the next print starts.
No printer tilting required — the printer stays level on your desk; no rigs, no ramps, no gravity tricks
Multiple eject patterns — edge_to_center, bottom_only, etc., with an in-UI preview
Built-in safety checks — Z-collision validation, multi-model compatibility check, and per-command G-code simulation before output
Dry-run mode — generates a G-code that runs only the automation sequence (no actual print) so you can verify the sweep on an empty bed
Works with stock hardware — a cold-release plate (e.g. CryoNix PUR) gives the most reliable results, but the stock textured PEI also works
Unofficial software, not affiliated with Bambu Lab. Please run a dry-run and watch the first full cycle before walking away.
It’s a fresh release, so bug reports, feedback, and PRs are all very welcome. If you try it, I’d love to hear how it goes on your setup.
Released under the MIT License — free to use, modify, and redistribute.
Thanks! Looks like you’re running a P1S — as far as I know, FarmLoop by 3D Farmers supports the P1S. But FarmLoop comes in a free and a paid version, and the free tier has some feature limitations.
This is working quite well for me but I am using a textured PEI plate and the printer is saying that I have a build plate mismatch. Everything looks to be in order as far as I can see, and the plate is called out correctly in the GCODE output from the software. I’m going to do some other debugging, but if you had any advice for why I am getting this error it would be greatly appreciated. I am a machinist and am comfortable reading and debugging raw GCODE for whatever that is worth.
Hi, This is likely because the build plate setting is fixed to “Smooth Plate” during BambuLoop GCODE conversion process. You can work around this by temporarily turning off the build plate detection option on the device. I will release an updated version to address this issue in the future.
I’m not sure, as the G-code for the H2D might differ from that of the H2S.
Since the H2S is the only printer I own, I would greatly appreciate it if someone with an H2D could assist with this project’s development—specifically regarding how the printer initialization G-code works on the H2D.
