BambuStudio 2.0.1.50 Bug with flushing volumes
In the new 2.0.x.x version, the flushing volumes window that allow to change the value of the flushing values from color to color isn’t working as expected.
Now, it doesn’t show the numbers in red when the flushing value is not enough for a proper change of the filament color.
i have the same issue, the reason its not showing red is because the suggested flushing volume range is [0,900] (0 to 900). Now i am searching the forums to see if this is because the minimum flush has been incorporated to the backend, or the program is not calculating the suggested flush values properly. this is the first post i seen mentioning it.
edit: for now i am reverting back to 2.00.00.95 just incase to see if theres a new version later on.
i reverted back and the issue persists
same here, can’t fix it even reverting to old vers
In my case I’m getting a blank page
Same here. I’m using a Mac. Issue started with new update.
me to i also use a mac and the screen is also just white
Same issue here on a Mac. I can revert to 1.10.2.76 and it works fine, later versions just a blank window.
Yeah same on windows, don’t know why…
I am using a Mac, and I am getting a blank window.
Same here. Running on Mac and it opens the window, and all I get is a blank white screen.
Same here as well. On a Mac…blank white screen when I click on flushing volumes. I’ve seen some notes that say re-install/etc/etc…has anyone tried any of these notes and had success? Or is this something that nothing will fix until Bambu updates? I hate chasing down troubleshooting steps when it’s known that they won’t help.
How do you revert to the old version?
