BambuStudio Flow Dynamics H2D BUG
Bambu Studio 2.0.3.54 Windows
H2D 01.01.02.04
If you go to perform a Flow dynamics calibration with filament in the LEFT nozzle it will run the right nozzle(and blocker) into the wiper and it will bend/rip the nozzle blocker off. Normally if it cleans the LEFT nozzle it will bring the print head in front of the wiper assembly and move it straight back, this straight back motion will lower the wiper when the right nozzle is raised. In the current calibration procedure it will simply come in from the side and exit from the side. The wiper is UP when the right nozzle and blocker move past it and it rips my wiper off and bends the nozzle blocker. Its acting the same as it would for cleaning the right nozzle but it should be moving around the wiper for the left nozzle.
EDIT: Just want to add this was while doing the AUTO flow dynamics from the calibration tab. This does not happen when I do flow Dynamics through the print screen.
I just want to make it more clear as I didn’t explain it great. This only happens if you initiate a Dynamic flow calibration through the actual calibration tab of the Studio software. This does not happen when I have flow Dynamics set to Auto through the print screen that would take effect at the beginning of a normal print. You actually have to go into the calibration menu, Select Auto calibration for the left nozzle. I found this out when I was trying to run different calibrations to fix some print issues on the h2d.
