Banding / Ringing type artifacts?
On official Bambu FB group, some one posted this :
Hope it could help many of you, results are pretty impressiv
Quite a few of us here do not, can not, shall not facebook. Can you copy and paste?
For reducing surface artifacts by mechanical adjustments there are a combination of factors that need to be considered, X-Y squareness, equal belt tension and belt rub on the idlers flanges. All these need to be addressed and will interact with each other during the adjustment process. It’s a subtle adjustment and very easy to go the other side of the bell curve giving the impression that the adjustment has had no impact. After careful and methodical adjustment to my machine the return to previous print quality proved that the issue was the squareness of the X-Y motion system and possibly belt tracking.
I think just holding the X gantry square to Y doesn’t give the required result. That is why I have a datum point (set square) that I adjust the X gantry to. This way you are able to see the effects of adding or removing preloaded from the adjusters. Both prints are done with the same filament and profile, the bottom print is after mechanical adjustments to gantry squareness and belt tracking.
and for the belt tracking :
Thanks for your writeup.
I only notice these artifacts on SILK filaments, since the Generic PLA Silk profile has a reduced max volumetric speed and thus prints slower.
Bambulab has released their own silk filaments… hopefully they have to do improvements on slow speed printing for them to nicely print.
It’s not clear how did you solved. Could you esplain how did you fix it? Thanks
I had mentioned previously that the belts tracking up and down on the pulleys could give artifacts if they were to touch the shoulder of the pulley
Another member in here had told me that was not an issue as the belts don’t track that high or low
Soooooooooo, was I onto something there ?
If that’s the case a smooth belt guide could keep the belt alignment and tension tolerances tighter but possibly at the expense of accelerated belt wear :thinking:
Ugh, so many ideas so little time
I’ve got far more projects than time for but I am making progress on a print bed project and dual auxiliary cooling fans prototype so that’s a good thing lol
I just forwarded a facebook post that I found helpful for those who experience this issue (actually, I’ve been waiting for mine for a week now…).
In my opinion, the belt tracking is important on the one hand to avoid wear related to friction and on the other hand to avoid a force that could harm the fluidity of movement
We can’t run a taller set of idlers but I wonder if a narrower belt could help :thinking:
Just watching this video and wonder if the extruder gears in the Bambu play a part? Slower speeds mean slower extrusion, printing faster may help as the filament flow is under more pressure than at slower speeds?
The root-cause is not the time-belt but something different. It is also not caused by the extruder gear.
I spend a lot of hours of testing and researching and am now 100% sure where the root-cause is and how it could be solved by Bambulab.
You can use a speed-tower to test the size of the pattern based on speed. It does not matter which one, but most important is to have speeds below 120 mms included, so you can notice the pattern differs per speed.
You can e.g. select the 40-220mms speedtower that I have created on printables, model 415784
I am communicating with Bambulab support, but unfortunately I’m dealing with Rick. Rick is very capable on communicative and manipulative area for pushing problems away from his person and letting other people do his job. But not the right person if Bambulab wants to improve with a real solution. Unfortunately Bambulab support (in the person of support-employee Rick) only wants to camouflage by providing different settings or other advise not being a true understanding and solution to the root cause.
At this point I’m curious if Bambulab as a company wants to be solving the issue or keep avoiding and waving it away.
Share with the rest of us, what you believe to be the problem, and the solution. I am curious to know what it is.
The community may be able to help getting this through to ā€œNot Rickā€ at BL Mothership.
I understand your curiosity and your need for the solution. However, sharing it here will not solve it. It can only be solved by Bambulab.
Furthermore, it is not related to open-source but to the commercial part of Bambulab aimed at making profit.
Would you spend a lot of hours working in favour of a company aimed to make profit without receiving a fitting compensation?
Below 120mm/sec you are seeing stepper cogging(mrr). Above 120mm/sec you see belt pattern rippling till around 180/200mm/sec.
The stepper cogging (mrr) is not constant with speed hence the spacing being wider/narrower as you move up / down in the speed range.
The belt pattern rippling is constant and independent of speed. It just fades away as the speed get’s higher.
For 1 you can’t solve unless you implement better micro stepping or tuning of the drivers to the stepper motors. Or use 0.9 degree steppers that will increase the frequency of the resonance making it less visible. Also slowing down to 20mm/sec makes things a lot smoother.
For 2 not sure what the answer is. Maybe it’s the belts rubbing against the flanges or belt resonance that can be tuned with increased or reduced belt tension.
References:
Well if you are looking to turn a profit on what you think is the solution, best of luck.
Even if you are right, and this is the key to the ringing, I would be very surprised indeed if you got anything from it, especially if you are holding it ransom.
Were I the company, who by and large has a massive success going, and some owner of my product knocks on my door and says;
ā€œHey, I found the issue that pisses off 1% of your users/potential repeat customers, but I want a cut before I tell youā€
I’d tell you to have a nice day, and thank you for buying my printer.
This is not a make or break issue for Bambu Lab…at all.
This is an issue for probably less than 1% of the users, and it’s cosmetic only, and only on certain types of prints. Less impact than the warped bed, which they admit to and are working on it.
For around $1,500 for a ā€œpremiumā€ printer with the AMS it is beyond frustrating. I’m wasting a bunch of filament just to get ā€œless ringingā€. A solution would be nice.
I agree, a solution would be nice.
Remember, this was marketed as a FAST quality printer. Stupid fast. Most owners are printing small stuff and don’t know it’s there. I did not find mine until I printed a cup holder adapter for my car, and even then you have to catch it in the light just right. Does not affect performance.
Those that are using it for cosplay, I suspect that it can be washed off in the vapor bath. Nobody has said either way.
Frankly, yes, and I think I did it many many times :wink: just think of all PrusaSlicer contributors…
I am experiencing similar issues. Pretty large artifacts on x in z direction (amplified on larger prints with big planes) and similiar though smaller artifacts on y in z direction. I am a design student in Germany and participant in FSAE. Therefore I wanted a printer which is fast, works and is precise. Latter the Bambu can’t fulfill rn.
I already Submitted a Support Ticket 7 Days ago, but no reply yet.
If they don’t publish a fix soon, I probably have to file a warranty claim next.
does anyone know how to upload pictures into the thread?
If I try to upload some it says I cannot embed media elemets into the thread.
