In case anyone was thinking to replace a smooth idler with a toothed one:
Carbon rods are glued into Y carriages
Carbon rod is in the way of the smooth idler axis, therefore carbon rod has to be removed prior to removing the axle
There are no access points that would allow to easily press out idler axis
My personal conclusion - it’s easier to print new Y carriages altogether and source new carbon rods somewhere, rather then attemp to disassemble whatever is on the printer.
Also this rises a concern: how does one replace an idler when it fails?
I’m going to see about getting a smooth or serpentine style belt because it’s far easier to swap out the drive motor pulleys in the back
My only concern is belt slippage especially during jerk moves but we shall see
First order of business is finding a belt that’s smooth on both faces then giving it a try running the printer at top speed and checking the print for dimensional accuracy and artifacts
Nice test there!
I know Bambu says to print faster but the trade off is matte looking PLA. A lot of times I want that shine, this is the problem for me.
Could you explain why? All that does in this application is change a belt tension - which is adjustable. You don’t want to change the size of a DRIVE wheel/sprocket/cog/wheel, that would change the speed and torque
FYI, measured the pulleys, 5mm bore, 10mm tall (complete height including flanges) 12mm diameter rolling surface. The 20 tooth should work as long as the flange doesn’t rub on the carriage, but it looks like there is plenty of clearance around it for an extra mm or two. The flange on the ones on the machine is a fair bit narrower and thinner than a regular GT2. Heightwise that doesn’t look to be an issue, but the diameter with flange of a standard 20T is 15mm(Gates brand)16-18mm (generics), which may need to have a bit of the radius trimmed off for clearance. Cant tell though until it’s tried. Diagram here is a Gates GT2 20T idler, 5mm bore.
There are clear artifact on the big circle while none on the little, facets can be viewed under Bambu Studio.
I am a bit surprise because I never had such problem on curves when exporting from Fusion360 to Bambu Studio especially when using step files rather than stl.
Yes obviously, I said at first, that it was a bit off topic ans related to the model not the printer, anyway thanks for the tips but… IMHO it could be considered as a bug, because the curves in Step files are stored as curves/NURBS and not as faces, so normally no need to specify a quality for Step file as they are already near 100%, that’s why I use Step files (rather than STL or 3MF because they convert models into meshs for saving and then lost the real curves).
The problem is that Bambu Studio convert the model imported into a mesh, I guess : first because it is easier to display even if they could have adjusted number of displayed face based on actual zoom… And second to slice it, this second point is for me a bug they should use curve from model to get G2 & G3 command rather than convert the model to mesh and then re-convert the slices of the model in curves based on a magic parameter …
The solution to my problem is just to set the Arc fitting resolution a bit higher 0.02 rather than 0.012, then it works well, but once again it is a dirty approch to convert a curved model to mesh and then try to guess where the curves was for slicing, rather than directly use the NURBS/curves available from the original Step model.
EDIT : I will go back to STL with a high quality on exported file, but that’s a bit frustrating that Bambulab added STEP files support and that they cannot be used correctly (STEP are not available in other fork of prusaslicer like SuperSlicer and I was pretty happy to be able to use such file format)
3D models are mostly expressed as triangular mesh, which means that the final slicing and printing path are dense line segments. When the printer is slow, these dense paths have no obvious bad influence on print quality. But when printing speed is high, A lot of transient impulse signals will be produced at the turning point of the segment, which brings about noise and vibration.
In order to alleviate this problem, Bambu Slicer generates arc path by fitting within a certain acceptable tolerance.
I said a it was “bit off topic” but interresting, I still posted it here because it could easily be confused with VFA, I thinked it was VFA artifacts for about 30 seconds.
There are 5mm dowel pins with thread down the center to allow them to be pulled out instead of pressed through, might be a good replacement for the stock ones for easier future removal once they have been taken out. I believe the original should also be able to get drilled and tapped to be pulled out the top, doing it at low speed in a proper drill press would be advisable.
I’m not sure about how much torque the current pin/seat can take before it would start spinning, so if you’re going to try this, probably go with M2 or M2.5 tap size. OD 5mm M3 304 Stainless Steel Female Thread Cylindrical Pin Locating Dowel Pins | eBay
