As the title states, I am getting “staining” on the bottom of my print.
BBL Matte PLA, Black.
Gold PEI Plate
Stock slicer settings and no glue.
First couple prints looked as you would expect, solid black and textured, now this. I did clean the plate and run another sample, same result. Anyone experience this before? Its not really a problem, but I would love to orient this part up so the texture is visible and with the “staining” I am not a fan.
I ran the test spool of basic PLA that came with my machine and did not see this on any of the prints. It was green not black though. I was wondering if something in the composition of the Matte finish is bleeding on to the bed?
I will pull a generic roll of PLA (Hatchbox) in black and run it. I did order some basic PLA, ASA and ABS from BBL to try as well.
Some use glue stick and a little heat or liquid glue to provide a barrier of sorts between the textured PEI and the print. That might stop the staining you are seeing.
Also, be sure to let the PEI plate cool before removing the part. They say it can damage the PEI to pull while warm/hot and that could be the kind of damage you see.
@R3d-Five Thanks for the feedback, its good to know it performs well for others. I love the finish and want to use it more. I will load it up later this week again and run some more.
Hi All, I have the same identical issue with my P1S and Bambu Pla Matte Black… I have this strange effect in the bottom first layer. With other filament (normal pla green and organge, pla marble, petg traslucent) the first layer has no issue. I have tryed all, calibration, flow static, flow dinamic, first layer height… In all the condition I’m getting this bad effect on the surface. No other issue, no adesion issue. I have also tryed to dry the filament for 12h but no change…
Some one found a solution for this? The matte filament is very beautiful, but with this first layer it’s limitiative…
Very new to Bambu but been 3D printing for years on glass, out of the box I have aP1S & AMS with all Matte colours and my first print on the gold PEI plate was superb in both texture and finish. The second print I could see a white haze on the black parts of the face that would not come off, I cleaned the plate with isopropyl and my next was the rear base for a clock - it felt like it was tearing off when removing cold this time and wonder if it could be the top layer adhering too well and the whit is the stretch in the fibres, I have reversed the plate being new to print the front in black also so it may be ok for a first print on this side, wish me luck (I will try a regular PLA if its not so good).
The white haze is called crazing, where stress of polimer chains introduces diffraction. Heat up those area to about crystalized point will release the stress.
Easy fix is to run heat gun over the hazed area. Candle or lighter would work as well.
I never use BBL filament to begin with. Say, paying AU$15 shipping on top of AU$50 was a deal breaker for me from the getgo.
Most of the time, I buy at least 10-20 spools from clearance or big sale, that costs me around AU$14 a 1kg spool of ABS, included shipping. Recently got a deal for AU$8 for a 1kg spool of PETG.
Just can’t imagine myself buying a PLA spool for $65. Anyhow, I do know a guy in Sydney bought an 800g Onyx spool (pa6-cf) for around AU$300. Crazy!
I had/have the same issue and was driving me crazy but I finally conceded and now use glue. Game changer. The parts adhere perfectly and as soon as the bed cools, they release with little effort.
Tried different methods, found if the bed is really cold they fall off. I have a glass cutting board that I sit mine on now and leave it, I have a second PEI board so I can print again while that one is cooling and it works.
