BBL P1S profiles missing?
Just bought a new Bambu Labs P1S with AMS, and setting up the slicer but the only options within the process profiles dropdown are those relating to the BBL X1C?
Is that expected?
Others seem to have been able to select P1P or P1S profiles. This is with the v1.7.4.52 installed from github.
Also as an aside, accessing the SD card from within Studio, that’s a X1C only feature?
It’s the same on my P1S’s. I believe the profiles are the same for all BL printers. Not sure why the add the X1C to the description though. Probably just a leftover from when that was the only printer they offered.
Same here, something seems off.
  1. All those X1C profiles use standard instead of Arachne perimeters, so they don’t seem to be up to date at all.
  2. There are P1P profiles in the settings directory and if you select the P1P printer, so not all profiles are identical.
  3. If all printers would require the same settings it would have been super easy for them to just copy and rename them to not confuse users.
These X1C profiles also don’t seem to have the buck fix for the print bed. When the print bed is far down at high prints, it moves to the bottom stop of the printer with a loud buzz noise. I continue to use my P1P profiles with the fan setting in the filament.
How can i find the P1S presets? All of mine are for X1C.
i have this same issue. Did you find a fix for it??
did you find a fix? im stilll with the same issue
Any fix yet? same issue on a new P1S - only X1C profiles after selecting P1S as printer
The P1S uses the X1C profiles. There are no P1S-specific profiles. From the standpoint of profile settings, the hardware is effectively the same,
