Bed adhesion damaging prints
Printer has been awesome for the first few months, then I went to print a ABS gridfinity base, and it was stuck so good I damaged it while scraping it off, and now all my prints are doing this.
I Tighten the Ceramic Base Screws and this didn’t help, so I adjusted my Z offset in the starting G-code +0.02, coming from Anycubic I was used to these issues daily, but this is the first time since switching to Bambu (1 year) I’ve had an issue.
Anyone else having bed adhesion issues with the H2D, mine only has ~416hrs of print time
I’m about to print a desktop filing cabinet for my invoices, and its a large print so curious if any one else has any solutions.
Edit* this is on the stock textured build plate
If your prints are sticking too aggressively to the build plate, you’ll need to either lower the bed and/or nozzle temperatures or apply a release agent such as glue.
Did you print on a freshly cleaned plate, or are you reusing the surface from a previous print? I’m asking because an overly clean PEI surface can actually grip too tightly—especially with materials like ABS or ASA. This is a well-known behavior with Textured PEI, and it’s why Bambu Lab specifically recommends using a release layer (like glue stick or Magigoo Original) when printing high-shrinkage materials on this surface.
For what it’s worth, I’ve personally never used the Textured PEI Plate on my H2D—it just doesn’t suit my workflow. I did use it briefly on my X1 Carbon while waiting for my CFX Plate, and while adhesion was strong, I didn’t run into the same excessive bonding issues you’re describing.
Also worth noting: cleaning the PEI surface with isopropanol or detergent can temporarily increase its grip. And while lowering the bed temperature can reduce adhesion, it comes with a higher risk of warping—especially for filaments like ABS that are sensitive to thermal contraction. The CFX Plate, which I eventually switched to, handles this far better with more consistent release behavior across multiple engineering materials.
If you prefer not to use glue, reducing the bed temperature might help—but you’ll have to balance that carefully to avoid warping or first-layer separation.
I am only a little over 100 hours into using mine, and I have only run ABS so far, but I haven’t had any issues at all. The prints do stick very tenaciously, but after cooling down pop loose so I can just pick them up. I have only washed my print plate once so far, and I used a lintless rag with 91% alcohol. I gave it a good scrubbing, and that was it. I haven’t used any glue or anything else.
Yeah mine was good for the first 300hrs, started giving issues after the 2nd to last firmware update but that might be a coincidence.
I will not be switching build plates or using glue, my P1S has the same build plate and has zero issues, as did my H2D for the first 300hrs
only running 70C for PETG and 90C for ABS, I needed to run hotter 80-90 on my anycubic’s
I am very new to 3d printing, but have you tried something more aggressive than alcohol, like acetone? Unless mechanical, I would be thinking that something had left a film on the plate. I guess you could try turning it over and see if that helps.
Acetone might damage the PEI surface so just be aware of that.
That reasoning is a bit like saying, “It worked on my old Volvo, so it should work on my brand new race car.”
I do understand the pride in avoiding glue—totally fair—but if you go that route, you’ll need to accept the reality of prints sticking too hard and solve the issue another way.
There are plenty of things that work great on my X1 Carbon but absolutely don’t on my H2D—and vice versa. They’re two very different machines, so applying the same logic across them doesn’t really hold.
Anyway, if you take a close look at the Textured PEI Plate from your P1S, you’ll likely notice the differences. I have two PEI plates myself—one from my X1 Carbon and one that came with my H2D—and I definitely wouldn’t call them identical.
Once you figure out what’s causing the issue, do share—would love to hear the outcome.
Hmm, my P1S and H2D PEI plates look identical, I know the older X1 carbons were different though… I wasn’t trying to compare them though this H2D didn’t have this issue for the first 300hrs. Changing my Z offset to zero from -0.02mm worked, this large print popped off easy. Its just annoying that I have to open my custom profile every time I open Bambu studio as it defaults to stock one when it syncs
I’ve rarely clean my plate I try to avoid touching it, and when I do I only use hot water and dish soap.
I printed some ABS and used HIPS for support. That HIPS material left a film on the bed that has been coming off as a white film on the past 5 or 6 prints. You cannot see it on the bed plate, just on the ABS.
I probably have the newer version of the PEI plate for my X1 Carbon, even though my printer is from mid-December 2024. Despite that, the plates differ quite a bit.
Over time, you’ll inevitably accumulate a few custom profiles in your filament settings—it’s just part of the 3D printing journey, so it’s best to get used to it. :wink:
That said, I completely understand that it can feel awkward to reapply them after every sync. Until the syncing issue with custom profiles is resolved, this is simply the reality we have to deal with.
By the way, since you mentioned needing to raise your Z-offset to 0, I gave my Textured PEI Plate a try as well. When I raise it to 0, I don’t get a perfect first layer—tested with a full-plate single-layer square—so our machines clearly behave quite differently.
Glad to hear you found a setup that works well for you!
One of the last firmware updates fixed it, and for your comment “you’ll inevitably accumulate a few custom profiles in your filament settings—it’s just part of the 3D printing journey”
This was true with my previous 3D printers, but the Bambu’s have been so perfect that if I have to tinker with them I find it unacceptable, I had to adjust my Z-offset every print on my old anycubic’s and babysit the first layer. But now I’m spoiled and expect every print to come out perfect.
Then you also have to accept less-than-perfect prints; that is unavoidable with 3D printing, because not every spool or filament will behave nicely just because the preset says so. We all think differently of course, but if it were the other way around and I could not tweak the profile, that printer would be on a one-way flight out the window.
I have found a solution that probably does not apply to everyone. My printer is in the basement next to a freezer. My prints (mostly PETG) also adhere enormously on the PEI plate. I printed something for the kids with a big base, took it out after the print and just put it into the freezer to cool down. 30 sec later, everything on the plate was completely loose.
Most of the time, if the print has enough surface area on the plate, the temp change from printing to cool shrinks the plate enough to nearly pop it loose. If the print is cool and the plate is cool and it is still adhered quite firmly, if you have a magnetic bed, pull the plate from the bed and flex the plate on the X axis and the Y axis and it should pop right off. If it is still stubborn, try rubbing some ice on the plate bottom and see if that helps. I use a SuperTack Plate and you figure it out with that thing in a hurry. Above all, be patient.
All of my CFX plates behave this way: if I let them cool down to room temperature, very few filaments still have enough grip to stay attached. My new Satin plate is quite different—it behaves much like the Textured PEI plate, but with a nicer finish on the bottom of the print.
CFX is my first choice every time, with Satin as my second. On my plate (Darkmoon CFX/Satin Duo), the required temperatures are almost the same.
